      04-30-2021, 04:41 PM   #1
knickerbocker
295/30/20 rubbing on stock ride height?
Hi all,
I'm running 20x11 et37, with 295/30/20 Michelin pilot 4s in the rear on a 2018 m3. On bigger dips at highway speed I'm getting a bit of rubbing on stock ride height.
I'm a bit surprised as I did some previous research and it seems this is a pretty common setup and I shouldn't be getting any issues since my car isn't lowered. I also ran the same setup on a 17 m4 with no issues, though I understand m4s have a bit more clearance.
Anyone else with this setup run into similar issues? Any suggestions on how to fix this?
      05-02-2021, 04:39 PM   #2
joludo
Drives: 20 M4 CS
What tire brand ?
      05-02-2021, 09:47 PM   #3
knickerbocker
Michelin pilot sport 4s
I'm hoping it can be fixed with camber adjustment. The drivers side seems worse than the passenger.
      05-02-2021, 10:07 PM   #4
guess2098
Drives: 2022 Taycan GTS, 2018 M4, 2016
I have 11.5 et38 with ps4s 295/30/20 cs stock height. As far as I can tell, if you have 11 et37 295/30/20, you will rub slightly due to not stretch enough.
      05-03-2021, 11:36 AM   #5
knickerbocker
Thanks for your insight. Been doing a lot more reading on the forums and it seems my setup is actually a pretty common one especially on the Signature wheels forum. Growing increasingly hopeful that it's just a camber issue. Will take it to the shop and take a look.
