01-12-2022, 11:05 PM | #1 |
Rep 3,726
Is this normal or is it a fluke? Filters were brand new when installed. The driver side seems to be much dirtier than the passenger side.
I tapped them out on separate paper towels so you can see the difference.
01-12-2022, 11:23 PM | #2 |
Rep 6,723
Cuz ya dirty!
Yeah definitely interesting find. I can jus think that one side pulls more air than the other. |
hellokitty2895.50 |
01-13-2022, 06:00 PM | #4 |
Rep 3,726
01-13-2022, 07:47 PM | #5 |
I'm Batman!
3948
Rep 1,477
But it really shouldn't unless one of the turbos is not spooling as good as the other (imho) I dunno
S55, 2JZ, M48.00 |
hellokitty2895.50 |
01-13-2022, 11:49 PM | #7 |
Rep 3,726
Figured it out!
The rubber air snorkel fell out of the area where the air scoops / front grill connects. I disassembled the air box and reconnected everything and used my leaf blower to test. Interestingly enough, my IATs appear to have come back down to normal. They were pretty high for a while and I couldn't figure out why. Something for you guys to check out
01-16-2022, 06:13 AM | #8 | |
Rep 884
Previously:
01-16-2022, 08:16 AM | #9 |
Rep 5,152
I'm assuming that the dirt that didn't go onto your filters was still sucked into the intake tube through the gap. A Blackstone and an oil change may be in order, along with pushing a clean rag through the insides of the intake. Just thinking ahead of possible probs.
Possibly your gap was before the filter (no debris up intake tube)…and that side was sucking hotter but cleaner air from under hood instead of the grill area? Pix of problem area please.
01-16-2022, 08:46 AM | #10 | |
Rep 275
01-16-2022, 08:57 AM | #11 | |
Rep 3,726
It looks like the air scoops do work but they also push in a lot of dirt and debris which is why the side that was connected properly was dirtier with larger debris. The area I am referring to is right in front of the grill rather than post air filter.
RElias21562.50 |
01-16-2022, 08:59 AM | #12 | ||
Rep 3,726
You need to make sure to align the clip from the passenger air box with the air tube otherwise there will be a huge gap and you'll be pulling air from right below the turbo hehe
01-16-2022, 09:16 AM | #13 |
Rep 3,726
Here is a pic. The rubber boot where air comes in basically fell out of the housing.
TopJimmy5458.50 |
01-16-2022, 11:29 AM | #14 | |
Rep 5,152
This makes more sense now. I've noticed a few chunks of grit in the bottom of my air boxes before. Since I use stock air boxes without scoops I think I'll add some black pet-screen over the duct openings inside my grill.
01-16-2022, 01:53 PM | #16 |
Rep 3,726
Looks ok to me. I'm assuming you removed the plastic mesh when you installed the scoops.
01-16-2022, 02:00 PM | #17 |
Rep 884
Yes I did. Am I not supposed to do that?
Previously:
01-16-2022, 02:02 PM | #18 | |
Rep 3,726
RElias21562.50 |
