10-18-2020, 09:30 PM | #1 |
Grid.Life
325
Rep 383
Official CCB Caliper Wheel Thread
Hi everyone! I'm struggling to find wheels that fit over CCB calipers so I thought it would help to start a thread listing what you've found that works or what doesn't work!
Here is what I've tried so far... Rays 57CR in 19x10.5 +35 - did not clear the front caliper due to barrel size being too small. Konig Ampliform 19x10 +28 - Cleared and the good news is they are cheap and relatively light at around 22lbs so they make for a great track wheel. Also this is has been a pretty worry free 275/35/19 square fitment with 7.5mm or 17.5mm spacers in the front. Last edited by F80Speed77; 10-19-2020 at 11:08 AM.. |
10-19-2020, 06:25 AM | #3 |
Rep 4,203
Do a forum search...it is all here
Many of the aftermarket units fit and most will say on their site. Most all 20's fit. 19's are stupid close even the factory wheels https://f80.bimmerpost.com/forums/sh...&highlight=ccb |
10-19-2020, 09:59 AM | #4 | |
Grid.Life
325
Rep 383
I probably should have clarified that I was mostly looking for 19" setups since nearly every 20" wheel fits. After searching around last night for a good bit and not finding a whole lot of solid info thought this might help be a one stop shop. |
10-19-2020, 10:03 AM | #5 |
Grid.Life
325
Rep 383
I'm on the Ground Control Coilover kit. You'll probably need at least a 7.5mm spacer on the front of the car with that setup but I'm currently running a 17.5mm and it looks great.
10-19-2020, 10:48 AM | #6 |
Rep 4,203
Understood..... I thought for sure there was already a master thread about what wheels fit CCB's. It has been awhile so I might be mistaken. I did go from the M4 to the M2 then to the Alfa 4c before returning to the M4 so that is a lot of variables. I can confirm the V-FF103 19's in F8x fitment are good. That is what i have but they will scratch like the OEM 19's
10-22-2020, 12:28 AM | #7 | |
Instagram: matte_f80_competition
127
Rep 219
18' M3 (F80) ZCP 6-Speed - IG: matte_f80_competition
Ind Frozen Dark Grey/M-Perf CF Pkg/MPE/KW CS 2-W/Girodisc+Carbotech/Vorsteiner VFF103 Track: Michelin Pilot Sport Cup 2 F: 265/35-19 R: 285/30-20 Street: Michelin PS4S F: 265/30-20 R: 285/30-20 |
10-22-2020, 03:46 PM | #8 |
Grid.Life
325
Rep 383
Is it the 19x10.5" Vorsteiner? I was thinking about trying to run those square.
///M3_N_DaWerks12.50 |
