05-27-2018, 03:22 PM | #1 |
Rep 1,632
Anyone running a flex-fuel system?
Since access to e85 isnt really easy in my area, i was wondering if some of you have installed a flex-fuel system that would allow your tune to adjust with the amount of e85 you have in your tank mixed with pump gas...
I like to drive a lot and travel with my car and running 100% e85 wouldnt be the best solution possible so im curious to see if a flex-fuel would be a good idea !! |
05-27-2018, 06:52 PM | #2 |
Rep 1,972
A true flex solution isnt available on this platform yet
Im hoping that with the m2c, the demand will finally be there for tuners to tweak their existing e-series flex solution to suit the f-series cars |
05-27-2018, 06:58 PM | #3 |
Rep 1,632
found this on google and thought it would have maybe be the solution...
http://www.fuel-it.com/s55-f-series-flex-fuel-kits/ |
05-27-2018, 07:53 PM | #4 |
Rep 182
I have the S55 DME code ready and partly tested. The firmware for the ethanol content analyzer is developing well. It would be released already except F series needs different ethanol content input method that required new hardware.
Commanderwiggin2050.00 |
06-06-2018, 01:06 PM | #7 |
Rep 620
interesting news. what tuning platform are you using for DME tuning?
06-06-2018, 01:22 PM | #8 |
Rep 182
MHD.
The DME work is finished subject to in car testing (works on bench), but the same build process runs well on earlier DMEs and so far every time something works on the bench it has worked in the car. I do many months of testing. The OBD flex fuel device works in prototype form, the prototype circuit boards are made and need soldering and testing. I am writing the OBD device firmware now to handle flashing, logging and realtime tuning. I already have the realtime tuning working on BMW and Audi in car but using third party J2534 cables. Whilst the flex fuel device has an OBD plug it does not have to be plugged into OBD but could be mounted elsewhere if desired, with wireless comms. The device has more inputs/outputs to use available pins and as far as I know this is the first time the aftermarket has used CAN bus for extra inputs/outputs which makes it highly expandable. Last edited by BMWcurious; 06-06-2018 at 01:29 PM.. |
06-08-2018, 08:47 AM | #9 | |
Rep 620
06-08-2018, 08:56 AM | #10 |
Rep 182
Yes.
It could connect to PT CAN directly by being wired in and hidden away, but putting it in an OBD plug gives the device flexibility to be used as an OBD interface and means that the connection to the ethanol content sensor itself need only be one wire routed from the sensor to the back of the OBD socket. I hope it will turn out to be easy and elegant in use. The original approach as per earlier BMWs was to use the DMTL analog pin, but that pin doesn't behave the same on later DMEs (in hardware or software) and there is a shortage of alternative analog pins that could be used across all models. I also didn't want to remove emissions equipment and require a pin to be added to a difficult to access DME plug for Euro models that don't have DMTL. Going in through CAN solves all these problems and leaves room for future ideas across many platforms too, so despite the extra development time it will be a good decision in the long run. An ethanol content device is needed anyway, since on S55 the factory direct input for the ethanol content sensor that would be used in Brazil is occupied by the second MAF sensor. Even a JB4 I believe has a separate ethanol content device rather than reading the sensor directly, although the fewer devices the better. As far as I know, most/every aftermarket flex fuel solution for OEM ECUs always has a frequency to voltage converter between the ethanol content sensor and a (hopefully) spare analog input to the ECU. Pulse trains are much more difficult to get into a reverse engineered OEM ECU directly as you usually get into some very low level OS code and cannot just deal with the hardware directly according to the chip's hardware manual. |
05-21-2021, 09:50 PM | #12 |
Rep 1
Question for anybody that can help. I bought the Zeintronix flex fuel reader. Of course the OEM fuel lines are not fitting over it. What are you guys doing to connect the sensor with stock fuel lines?
Any adapters? Have to cut lines? SEND HELP lol |
05-21-2021, 10:12 PM | #13 | |
Rep 552
Drives: 2018 M4 ZCP 6MT
https://www.bendcalibration.com/shop/bmw-f8x-flex-fuel
2018 F82 ZCP 6MT: FBO, Kratos KRAS55Bi, EU5 Injectors, Dorch HPFP Lift Kit, Stage 3 LPFP, Bend Calibration Zeitronix ECA-2, BM3 Flex-Fuel Tune by ABP
For Sale |
05-21-2021, 10:16 PM | #14 | |
Rep 2,711
05-22-2021, 09:31 PM | #17 |
Rep 1,375
