12-11-2022, 03:05 PM | #1 |
Rep 9
Tire fitment question
2017 M3 with 19x9.5 + 20 and 19x11 + 35, car is on swift springs. Anyone know if 275/35/19 and 295/35/19 will this work without rubbing? The car came with BC forged rims in this size.
12-13-2022, 05:28 AM | #2 |
6579
Rep 5,304
Guaranteed to rub on the front due to diameter. The rears may or may not rub, depending on your suspension and alignment.
DriveandBang4.50 |
12-13-2022, 09:35 AM | #3 |
Rep 9
12-13-2022, 10:28 AM | #4 | |
6579
Rep 5,304
I knew one guy who had a large diameter tire on his 3 series that rubbed. He lowered his tire pressure to 20 psi and then told people it doesn’t rub. If you don’t consider touching the fender liner when you turn the wheel rubbing, then yeah sure, it’ll work just fine. Granted you can get over how ugly a 275/35/19 will look on a 19x9.5, have at it! |
DriveandBang4.50 spidy512491.50 |
12-13-2022, 11:41 AM | #5 | |
Rep 9
12-18-2022, 06:18 AM | #6 |
Rep 1,074
I run 265/30 front and 295/30 rear
Instagram: M2_Medusa
12-18-2022, 08:44 AM | #7 |
Rep 3,726
I had to take a heat gun to my (now cracked) fender liner on a 275 setup to stop the rubbing.
There is still a very slight rub at full lock, but I’m going to wait a bit to see where I need to target. It basically solved 95% of the rubbing issues. You need to heat both ends (near the front radiator as well as the same location near the driver side door. Only the front driver side rubs for me.
12-18-2022, 09:58 AM | #8 | |
Rep 124
It’s due to the fact that I am running the G8x MPS4S Star Spec front tires. It’s tread width is actually thinner than the previous 265/35/19 PS4S tire I had When I ran 265/35/19 on OEM wheels with a 10mm spacer (19x9 effective ET19), it rubbed slightly during turns. I was going to drop down to a 7.5mm spacer to alleviate this but they weren’t in stock at the time and I ended up switching wheels |
12-18-2022, 10:02 AM | #9 | |
Rep 124
Go with the advice above and don’t force it to work |
