11-10-2020, 04:23 PM | #1 |
Rep 889
Manual Transmission - CDV Question
Hey Folks,
I have a 6MT ZCP F80 with a Stage 1 93Oct BM3 tune, and as I've recently started to drive the car harder, I've noticed a little delay in power coming on immediately after a quick shift. If my memory serves me correctly, my old 2010 335 used to have a similar issue caused by a Clutch Delay Valve. I think it was a pretty simple swap in that car. Does anyone know if there is a CDV in the F80, and if that is the cause of what I'm feeling? I have not been able to find a definitive answer from searching. Alternatively, anyone have any suggestion re: how to remedy this issue? Thanks!
Previously:
11-10-2020, 06:24 PM | #2 | |
Rep 369
///M3
11-10-2020, 08:32 PM | #3 | ||
Rep 889
I would be surprised if I had a faulty part. Bought the car with 3k miles on it. Has 11k now and I don't beat on it.
Previously:
11-10-2020, 08:38 PM | #4 |
Rep 391
Could be spark plug issue? You may get better response between gears by running colder plugs. Just a guess ?
_____________________________________________
E46 wagon ~ E46 330ci ZHP ~E46 M3 Sold ~ E92 335i Sold ~ E90 M3 Sold ~ F82 M4 Sold <- All Manuals |
11-10-2020, 08:51 PM | #5 |
Rep 53
Here is how to remove it. I'll probably have mine done next spring. It doesn't look hard, but I don't want to deal with the mess or making sure the lines are properly pressurized afterwards.
https://f87.bimmerpost.com/forums/sh....php?t=1625114
2020 M4 Convertible 6MT, 2010 S4 6MT, 2019 X3 m40i
11-11-2020, 12:38 PM | #6 |
Rep 122
I removed the restrictor on the slave cylinder and the bite point on the clutch is definitely more consistent and easier to modulate as well slip off the line but I will say the car still loses some boost for a split second on upshifts... it seems like the more boost I run in midrange (target boost of tune) and the higher I rev before shifts (where the boost tapers below target) the longer it takes to recover on upshifts... so if I short shift before the boost tapers it holds much better to the point it gets seemless... this is with stock turbos fwiw not sure if it’s better on bigger turbos running boost levels within their efficiency range that can hold target all the way to redline
11-11-2020, 12:57 PM | #7 | |
Rep 889
I'm surprised this isn't more a topic of discussion on this forum and how to address.
Previously:
whitstap79.50 |
11-11-2020, 02:25 PM | #8 | |
Rep 369
The link posted a few replies above about covers it. I didn't replace the CDV with anything else, and experienced no leaks.
///M3
11-12-2020, 12:09 AM | #9 |
Rep 513
This. CDV delete takes about an hour. Did not like how this car drove before doing it, now its back to what I expected. Definitely recommend.
11-12-2020, 11:38 AM | #12 |
Rep 4,001
nope, it did not , I've had multiple M cars throughout the years, some did have it and some didn't. For example my 08 E90 M3 had it and later my 10' E92 M3 didn't. Not sure why but I always check to remove it when flushing the brake fluid since I do track my cars.
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
11-12-2020, 11:47 AM | #13 | |
Rep 513
11-16-2020, 09:23 PM | #14 |
Rep 31
To get rid of the CDV on my F80 I bought a slave cylinder from an E90. It's the exact same part but does not have the flow restrictor inside. I have yet to install it, but I can't wait to get it on there, as the clutch 'feel' on my car right now is basically non-existent. It's nearly impossible to get off the line smoothly, and I've tried enabling, and disabling rev matching in all drive modes. I got rid of the CDV on my previous E36 M3 and E90 335 - it always helps!
2016 F80 M3 • Individual (1 of 1 in the US) Venetian Violet Pearl Effect • Silverstone Interior • 6sp. Manual • Carbon Roof • 666 Wheels
11-16-2020, 11:11 PM | #15 |
Rep 513
https://f30.bimmerpost.com/forums/sh...1486773&page=5
I followed this method (post is in the middle of the pace), no drilling, just used a screw to pull out the “restrictor” CDV metal washer. Didn’t mess with any orings or have to remove anything. Best free mod for the 6MT! |
m3elmo49.50 |
11-17-2020, 07:35 AM | #16 | |
Rep 369
///M3
11-17-2020, 08:58 AM | #17 |
M Power
43
Rep 50
I did the clutch delay valve removal myself last month, definitely recommend it. Big difference in clutch feel and smooth driving is much easier. I mentioned this mod to the senior shop foreman at dealer service dept, he said BMW has been using these delay valves since E36 days for hill assist in manuals. They even call it the hill assist valve between techs.
I recommend ordering a new slave for three reasons: 1) You have a backup in the original slave in case you mess anything up. 2) It's a wear item. 3) It's cheap. The part # is 21-52-6-795-713 and runs about $90. Also highly recommend using the Motive pressure bleeder to bleed the slave yourself, makes that much much easier. Here's what you're after; |
11-17-2020, 11:16 AM | #18 |
Rep 1,976
Sounds like a good mod!
Yet, this was installed by the factory for a reason. What are the negative consequences of doing this mod? |
11-17-2020, 11:30 AM | #20 |
Rep 513
11-17-2020, 10:54 PM | #21 |
Rep 117
I'm so happy to see this thread - I just got my F80 and was not understanding why the car feels like there is a slip of the clutch at the top. Or as the OP describes as a delay in power onset...i need to do this mod!
Danny
Bay Area, CA |
11-18-2020, 06:24 AM | #22 | |
Rep 369
This also improved the feel of mine
///M3
