ARMA SPEED
      05-25-2021, 03:37 PM   #1
S2000_Europe
Drives: M3 Comp. Tazanite Blue
Hello,
I recently bought an M3 Comp 2017. Mechanically is good but the shop told me that the DME came with a tune. He reseted the DME using bmw software but he still having issues with misfire in cylinder 3,4,5
the car has 40k miles, coils are good, leak test good, new spark plugs ( had one with a step colder)
How can I delete the software and have the original back?
I do not want to drive the car and don't want to buy a new DME.
I am located in Miami
Thanks
MY02 S2000 > MY11 STI > MY01 E46 M3 > MY05 S2000 > MY06 911 C2S > MY88 944 TURBO S > MY17 STI > MY17 SS 1LE > C7 GS w/ ZO7 package > MY18 ZL1 >MY20 F87> MY17 F80 ZCP
      05-25-2021, 04:21 PM   #2
theweebabySeamus
It sounds like the shop already reset it to BMW software so it's not tuned anymore. You have a cylinder 3 misfire that needs to be troubleshot.
      05-25-2021, 04:22 PM   #3
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
Drives: E90M/E92M/F80CS/X5 35/MiniCS
It's possible the misfire is due to the different plugs and having an oem tune now
      05-25-2021, 04:48 PM   #4
S2000_Europe
sorry if I did not explain myself correctly. Misfire is in cylinders 3,4,6
the shop installed the original plugs and changed the coilers and reset all the software
Could be the injectors?
      05-25-2021, 04:51 PM   #5
SYT_Shadow
SYT_Shadow's Avatar
I don't know. Plenty of asshats are running E85 and doing all kinds of things on leased cars, then return them and you're left trying to figure out what they did
      05-25-2021, 09:19 PM   #6
S2000_Europe
Know I understand why bmw lock the DMEs
If I get more info I will post it here. Tomorrow I am going to another shop who is specialized in M3, If this do not work I will try Active Werke and the last resource the Stealership
      05-26-2021, 10:00 AM   #7
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
20% OFF MAD PRODUCTS - AUGUST SALE||https://x-ph.com/sale/
Phone number 702-494-9435
      05-26-2021, 04:59 PM   #8
MisterF80M3
MisterF80M3's Avatar
918
Drives: 2018 M3
What tune was on it originally?
2018 BMW F80 ///M3
570WHP/578TQ
      05-26-2021, 06:30 PM   #9
S2000_Europe
bootmod3
      05-26-2021, 06:33 PM   #10
TopJimmy
TopJimmy's Avatar
Drives: BMW M3 F80
bootmod3
Just email PTF and ask them for help flashing your car back to stock. They can get their tunes uninstalled.
'18 F80 Base 6MT | Paul's E85 | Stock Turbos | Kies Hub | FBOs | 7sec 60-130 | 11.7sec 1/4mi@124
      05-26-2021, 06:34 PM   #11
S2000_Europe
update
we found that the intercooler is leaking.
next steps, change intercooler, replace coil cables and check if spark plugs where installed correctly
I still do mot understand why the other shop updated the DME software to the 2020 version
      05-26-2021, 06:43 PM   #12
S2000_Europe
bootmod3
we the shop update the DME the tune was deleted. But the first shop insisted that the tune was still the.
the second shop notice that the intercooler was leaking and is performing to change the coil cables, the first shop said it is not necessary.
History shot my car went to the first shop running well, just a revision and to check all was clear, and leaved with misfire in cylinder 3,4,5
      05-26-2021, 08:54 PM   #13
MisterF80M3
918
Drives: 2018 M3
Are you 100% sure you are on stock tune?
2018 BMW F80 ///M3
570WHP/578TQ
      05-27-2021, 07:35 AM   #14
S2000_Europe
I am sure, I spoke with the shop who installed and uninstalled the tune. I assume that after reseting the DME with the 2020 ISTA software f the were any tune, it would be deleted
      05-27-2021, 12:43 PM   #15
S2000_Europe
update 2
The second shop was right, installed M performance coil cables and now the M3 runs perfect. The first shop still insist that the DME is damage.
Intercooler was leaking
The car runs a bit lean, the mechanic found that the car had an aftermarket intake and when retrofit it to stock the MAF sensor was not installed correctly so the air pass through it
Word of advise, never update the ISTA to the last version, because sometime has bugs. That is the reason why shop two could not communicate with the DME with its 2019 version, is like Windows, if it works do not fix it!
      05-27-2021, 06:42 PM   #16
TopJimmy
TopJimmy's Avatar
Drives: BMW M3 F80
You got it. The latest software update for the DME will also lock you out of Bootmod3. Rat badtids!
      06-01-2021, 12:31 PM   #17
S2000_Europe
more news,
no more misfires but one oxygen sensor, before cat, is reading lean mixture. While his twin is not.
So seems that needs to the replaced.
The mechanic told me that some "kids" likes high popping noises with their tune. That is really bad for the sensor.
Last time I buy an used BMW
      06-01-2021, 01:29 PM   #18
CubicMeters
CubicMeters's Avatar
12
Drives: BMW M3
Last time I buy an tuned BMW
Fixed
      06-01-2021, 01:43 PM   #19
S2000_Europe
Fixed
the car was stock and serviced at bmw dealers.
This also proof that carfax is worthless
      06-01-2021, 05:05 PM   #20
CubicMeters
12
Drives: BMW M3
Sorry guess I misunderstood the original post.
Carfax does what it does. Certainly a "clean" carfax isn't an unequivocal green light on any vehicle. As they say: absence of evidence is not evidence of absence.
      06-02-2021, 06:09 PM   #21
S2000_Europe
The car now runs like a champ!
the problem was the o2 sensor.
The shop did a leak test and a compression test and all was perfect.
Thanks all for your help
TopJimmy1455.50
SYT_Shadow8320.00
audioMeth137.00
      06-02-2021, 06:34 PM   #22
TopJimmy
TopJimmy's Avatar
Drives: BMW M3 F80
Glad it's fixed.
Strange how the problem occurred across both banks (cyls 3,4,6) with just one sensor failure.
