      06-10-2021, 10:41 AM   #1
Schultz28
Drives: 2015 F80 M3
New Release: BMW S55 Nostrum Stage 1 Injectors
Just came across this newly released part from Nostrum!
Seems like it will be a nice upgrade from even the EU5 injectors!
https://www.nostrumshop.com/product/...e-1-injectors/
BMW S55 NHP Stage 1 Injectors
SKU: H610-1163
1200cc/14.45 g/s Upgraded direct fuel injectors
33% Increase in fuel flow over stock
Full ethanol compatibility
Operating Pressure: 20 mpa
Direct fit No modification required
Tuning guide available with purchase of product
Application List:
F80 M3F82/F83 M4F87/M2 Competition/CS
Tuning Capabilities:
EcutekBootmod3 Coming Soon
      06-10-2021, 11:18 AM   #2
-Eidos
Low Boost Boy (LBB)
173
Drives: 2018 BMW M2 (LBB)
SKU: H610-1163
Direct fit – No modification required
Application List:
EcutekBootmod3 – Coming Soon
The EU5 S63s flow just as much if not more than these at a lower cost with warranty.
The stage 2s that they're working on will be more interesting.
EDIT: A pro for the Nostrum injectors is that the calibrations are coming to the OTS platforms like Bootmod3 so that will be convenient for people not running custom tunes. That said, would be nice to see these OTS platforms provide EU5 toggles as well.
Speedtech Stage 3 (7670) | Remus Exhaust | Wagner EVO 3 | Custom Stage 3 HPFP | EU5 M5 Injectors | Walbro 525 | EOS EKP | BendCalibration Flex Fuel Kit | MSL Thermostat | TC Kline | RKP | 3DDesign | TRE
Full E85 DI-Only 620WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      06-10-2021, 11:55 AM   #3
Schultz28
Drives: 2015 F80 M3
Interesting. I was reading somewhere that the EU5's are a 15% increase in flow and these show 33% increase in flow. I am sure we will see some more numbers from them soon.
Either way, finally starting to get some more aftermarket fueling support. I am sure we will start to see many more injector options for these cars soon, supporting all power levels.
      06-10-2021, 12:29 PM   #4
FriedPiston
Drives: Scraper
I've mentioned this to Brandon. These are possibly rebranded EU5s with markup pricing.
S63 EU5 = 903 g/m (15.05 g/s)
Nostrum = 867 g/m (14.45 g/s)
It's probably best to wait for an independent flow test before shelling a cool grand on these injectors. I would put this product in the same category as Ignition Projects (Okada) coilpacks unless proven otherwise.
      06-10-2021, 12:33 PM   #5
FriedPiston
Drives: Scraper
Maybe not even a pro over traditional ISTA coding if you ever need to flash back to stock for various purposes... I can imagine a diagnostics nightmare if the injectors rely solely on a tuning flag in order for them to work correctly.
      06-10-2021, 12:45 PM   #6
-Eidos
Low Boost Boy (LBB)
173
If they are a variant of the EU5s then they'll need to be coded anyways on top of the tuning flag.
      06-10-2021, 01:05 PM   #7
///BMW Junkie
///BMW Junkie's Avatar
Drives: AW M4
Do you have the S55 EU6 flow figures?
Pure F82
      06-10-2021, 05:39 PM   #8
chewbakam4
chewbakam4's Avatar
641
Drives: F82 M4
They seem just M5 EU5 rebrand to me as well.
      06-11-2021, 11:41 AM   #9
Schultz28
Drives: 2015 F80 M3
Well, that is kind of a bummer!
Yeah, I wouldn't spend any money on them until there is some actual tests/dyno results.
But it's still nice to see more fueling options to stay DI.
      06-13-2021, 05:58 AM   #10
CAOZKAN
Drives: Austin Yellow M4
Can I buy directly EU5 s63s and install it without any tunes? I mean Bosch ones 0261500136..
      06-13-2021, 07:16 AM   #11
TopJimmy
TopJimmy's Avatar
Drives: BMW M3 F80
No, a tune is required to run big injectors.
'18 F80 Base 6MT | Paul's E85 | Stock Turbos | Kies Hub | FBOs | 7sec 60-130 | 11.7sec 1/4mi@124
AND1_M340.50
      06-13-2021, 04:40 PM   #12
Wanted_M
Wanted_M's Avatar
Drives: Frozen Blue M4CS
^^That blows for smog purposes as you have to flash stock map in CA, another headache.
M4CS Frozen Blue
Dinan HAS | Dinan x-pipe | Fall Line links | Hotchkis bars | K&N | Spiegler |TC Kline plates | Xpel stealth
