      06-11-2021, 12:12 PM   #1
stevehifi
Drives: 17 F80 M3 ZCP
6-speed short shift kit options
Hi Guys,
Looking at the various short shift kit options:
-Turner Motorsports
-UUC
-Rogue Engineering
-Auto solutions
I know alot of people like the Auto solutions one but I'm not looking to get under the car and do an elaborate install. It looks like the Turner one you can do it from inside the car.
Anyone have the turner one installed and can comment or even the UUC or Rogue one?
Thanks,
Steve
      06-11-2021, 02:11 PM   #2
Phatazz7
Drives: BMW, Audi, Toyota
Every shifter will require you to get under the car to install. The turner is a bit easier among others because its only the shifter lever and bearing the rod stays the same underneath. The Auto solution will require you to replace both the lever and the rod and is a bit trickier to install but not over the top. Ive gotten it down to probably 1-1.5 hrs to install or remove the shifter from this car.
      06-11-2021, 09:33 PM   #3
jpy1980
jpy1980's Avatar
Ive always been a proponent of the CAE shifter. I have it and, like you'll hear from many others who installed it, its the best mod I've done to the car.
Everyone who drives it is also amazed...You're in Irvine, if you're ever up in WLA, you can check it out.
      06-11-2021, 09:36 PM   #4
chetrickerman
ECUTek Master Tuner
chetrickerman's Avatar
Drives: F80 M3 YMB
2016 BMW M3  [0.00]
I have heard that too, but the only reason I didn't get it is because of the need to cut the cupholder and interior trim.
Torque is a measure of an engine's ability to do work; Power is the rate at which work is done
      06-11-2021, 09:39 PM   #5
jpy1980
jpy1980's Avatar
Its really not bad. I cut my original and patched it up so I could use both cup holders fine. I also bought a used cup holder on ebay for like $60 just in case I go back to stock.
Kossos133.50
      06-15-2021, 08:26 AM   #6
shonuff1
Like someone else said, any short shift kit you buy will require working from underneath the car to disconnect the shift lever from the linkage. I installed the AS kit in mine, it took me a while but it was worth it.
The nice thing about AS is that Ron will customize the shifter to exactly what you want. The downside is that there is a 2-3 month lead time on AS kits since each one is custom.
      06-16-2021, 12:01 AM   #7
ByeFelicia
ByeFelicia's Avatar
361
Drives: F80
Autosolutions is worth the lead time. Have one and its a must for a manual.
SYT_Shadow8320.00
      06-17-2021, 12:34 AM   #8
x.shell
x.shell's Avatar
5867
Drives: ▋ ▉▉
Now you guys got me thinking about Auto Solutions. I might as well give it a go; I've tried everything else.
      06-17-2021, 10:11 AM   #9
chetrickerman
ECUTek Master Tuner
Drives: F80 M3 YMB
2016 BMW M3  [0.00]
We look forward to your assertation of the AS kit.
      06-17-2021, 10:52 AM   #10
Kuucheki
Drives: 2018 BMW M3 Competition Packag
Which configuration did you go with? I'm thinking 25% reduction in throw, oem position/height and 80a grade bushing.
      06-17-2021, 12:34 PM   #11
ByeFelicia
ByeFelicia's Avatar
361
Drives: F80
Per Ronald:
A shorter throw that is positive will be reached with a 25% shifter. dropping the height 10 mm will increase that ratio from 25% to close to 30% which in my opinion is plenty short.
(+ 95A bushing) sounds like a great place for me to finalize.
25% reduction - 10mm drop - 95A - I've added the non light up mperformance shifter and that has dropped height even further.
This is all positive and love my setup.
Kuucheki
      06-17-2021, 03:18 PM   #12
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
Drives: E90M/E92M/F80CS/X5 35/MiniCS
Autosolutions for sure out of the list you provided
The CAE shifter is fine, but not for a street driven car unless you like a lot of attention
      06-18-2021, 02:14 AM   #13
Kuucheki
Per Ronald:
Kuucheki
Thanks. Does the 95a make gear changes loud?
      06-18-2021, 03:35 AM   #14
ByeFelicia
ByeFelicia's Avatar
361
Drives: F80
Kuucheki
IMO, No.
But I am catless and hear more of that than the shifter.
Get the 80A+ if additional noise is an issue for you.
I welcome all the noises so thats why I chose it.
      06-18-2021, 08:31 AM   #15
irunalot
Drives: 2018 M3 Comp
Auto Solutions, I got the 25% reduction with the 80a bushing.
I also added the Rogue rear transmission mounts.
      06-22-2021, 02:25 PM   #16
shonuff1
My Autosolutions kit is 15% reduction, stock height & position, OEM bushings and new OEM tranny mounts. I wanted to eliminate the slop, shorten throws by a small amount and minimize NVH so I went with stock bushings.
After doing the installation, I have to believe my throws were reduced by more than 15%. Maybe 15% is the amount he's shifting the pivot ball up on the lever which magnifies the throw reduction, I don't know but I feel like it was more than 15% reduced.
Either way, I'm really happy with it.
      06-25-2021, 10:03 PM   #17
Tommy L Garage
Drives: 2017 YMB M3 6MT CP EP VP
Question:
I want to get rid of the rubbery feel of the shifter. I want it to be more mechanical, similar to my 981cS.
Any idea what would be the upgrade to make the oem shifter feel more mechanical? I don’t mind the throw or height…I just want it to click in place and not feel spongy.
Thanks!!
      06-25-2021, 11:03 PM   #18
to_riffic
to_riffic's Avatar
Drives: rwd
Send a message via AIM to to_riffic
Originally Posted by Tommy L Garage View Post
Question:
Thanks!!
Don't know if Autosolution bushings work with the stock shifter or not, but if you get the 80a (medium) bushing, it would alleviate the mush you're talking about. It clicks right into each gear.
loud noises
      06-26-2021, 07:53 AM   #19
Tommy L Garage
Thanks! I’ll give it a try
      06-26-2021, 06:01 PM   #20
iDriftYou
iDriftYou's Avatar
Drives: 2018 BMW M3 ZCP 6 Speed
I have the IRP chassis mounted shifter, probably the best mod I have done to the car as far as feel is concerned, I'm not a fan of short shift kits, the IRP shifter was the shortest throws out of anything I've driven, CAE and RTD don't even come close.
      06-26-2021, 07:01 PM   #21
1000hp
Just installed my Auto Solutions shifter and Raceseng 500g knob today. Feels absolutely perfect. Very precise but no notchiness. Absolutely no rubbery feeling.
I didn't install the supplied bushings because I didn't feel like dealing with it after getting my ass kicked for two hours trying to install the carrier screws, and then realizing that I would have to take those screws right back out and remove the carrier to replace the bushings. It was a rough day.
I can confirm that their carrier bushings will work with the stock shifter, but the big monoball and socket on the AS shift lever are not transferable to the stock lever as far as I can tell.
      06-27-2021, 12:10 PM   #22
RElias21
RElias21's Avatar
Drives: 2017 30 Jahre M3
Question:
Thanks!!
Tommy, when are you looking to do this?
I just ordered mine, and was told there are 103 people ahead of me. Estimated October delivery.
After speaking with Ronald, we agreed on the following:
Previously:
2010 E92 335 (6MT)
2011 E92 M3 ZCP (6MT)
