05-07-2021, 10:37 AM | #1 | ||
Rep 3,538
Drives: 328d Wagon, M2 Comp, i4 eD35
A Look into the DSC Brake Bleeding Routine
It's pretty commonly mentioned that there's a "DSC bleed" that's sometimes needed on these BMWs, but I didn't see any information out there actually showing the process. On the surface it sounds pretty simple, use a scanner device or ISTA to activate the DSC module and bleed fluid, but the routine is actually more complicated than that. I'll show you below what the routine looks like in ISTA.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-07-2021, 11:04 AM | #2 |
Rep 3,604
Thanks for this! This has been the impetus for setting up ISTA for me, so appreciate the walk thru on this specific function
Current: F80
Prior: F82, F32 |
05-10-2021, 01:42 PM | #4 |
Rep 348
I did this last weekend .... thank you for putting this together. I just noticed you need to press the brake pedal hard in order to avoid getting the error message. With the good tips was straight forward.
05-10-2021, 04:46 PM | #6 |
Rep 3,538
Yup, I do it solo all the time.
Open bleed screw, hurry to driver's seat and press on brake pedal, then hit continue on laptop, pump the pedal a few times, then hurry back to caliper to close the bleed nipple. Hahaha.
05-11-2021, 07:41 AM | #8 | |
Rep 317
05-11-2021, 09:36 AM | #9 |
Rep 3,538
No changes needed for BBK or multiple bleed nipples (the stock calipers have multiple) since the DSC bleed is to be done after and before a regular/conventional bleed. So you only need to use one of the nipples on a multi-nipple caliper when doing the DSC bleed. In the regular/conventional bleed is where you make sure to get fluid out of both bleed nipples.
dvq319.00 |
05-11-2021, 10:46 AM | #10 |
Rep 1,730
Damn wish I saw this thread before doing a flush.
What about for the dct clutch. Is there a similar bleed function that we need to follow?
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
05-11-2021, 03:47 PM | #11 |
Rep 1,481
Been bleeding my brakes myself for the 5 year+ i've owned the F8X never did this following the manual bleeding procedure.. just a traditional power bleeder attached to the reservoir and me running around all 4 corners bleeding and refilling the reservoir before it dips and air enters the lines.
What exactly does this DSC bleed procedure do? Basically uses the computer to individually bleed the corners? (really asking, because I literally skipped this twice now). Or how does one know they need to do this procedure? |
drroc420.00 |
05-11-2021, 06:56 PM | #12 | |
Rep 518
JamesGames1326.00 |
05-24-2021, 04:40 AM | #13 | ||
Rep 138
In the video while he's running ista, there are instructions on the right side of the screen. States it's only done if dsc unit or brake master cylinder were removed or one of the lines in between were disconnected. Sounds like anything downstream as in replacing soft lines or calipers for example, isn't affected and there's no need for bleeding dsc. I'm surprised by the suggested brake bleeding sequence in ista. Rear left, front left, front right, rear right. Sounds like great deal of German engineering went in that one and it kind of makes sense when working on the driveway. Much faster lifting whole side of the car instead of front-rear or each corner individually. I think we're all doing RR,RL,FR,FL |
FaRKle!4014.50 |
05-27-2021, 03:06 PM | #16 |
Rep 518
So I swapped to a BBK and had one line empty for quite a while while I was dealing with issues with the manufacturer over two weeks. I didn't even depress the brake pedal. I flushed the fluid when I got everything sorted out, and things appear to be fine. Maybe the DSC module never got any air in it and I lucked out.
05-28-2021, 10:32 AM | #18 | |
Rep 3,538
05-28-2021, 03:19 PM | #19 | |
Rep 518
02-17-2023, 09:09 PM | #20 |
Rep 72
Great post!
Curious if you ran the power bleeder dry and just refilled the reservoir? Thats always my preference, but not sure if on the front or rear axle circuit there is a risk to run the reservoir dry. |
02-17-2023, 10:47 PM | #22 |
Rep 3,538
I never put fluid in the pressure bleeder (I don't want to clean it). I fill the reservoir till full, push it through till it reaches the "min" line, take the pressure bleeder off, refill the reservoir full of fluid again, then reconnect the pressure bleeder to push again. You never want to run the reservoir completely dry!
