ARMA SPEED
      12-04-2022, 09:13 PM   #1
c99782
c99782's Avatar
Drives: 997
Pre-LCI LED to Adaptive LCI2 conversion
Hi all,
Looking to convert my pre-lci car with the adaptive led to an lci2 headlight set. What hardware is needed additionally?
From my understanding, modules and harnesses can be reused from the pre-lci led? Would I only need empty lci headlights and be able to retrofit them with the hardware already in my car?
TYIA
      12-05-2022, 05:17 AM   #2
NSX2M4
NSX2M4's Avatar
1354
You need LCI2 modules 3 each, headlights, wiring kit for LCI2, and coding. If you have no high beam assist button on your blinker switch, you need a clock spring with the button if you want to truly go full adaptive. (light just corner without it)
