02-19-2019, 07:38 AM | #1 |
Rep 984
Latest ECU and TCU updates?
Hi everyone,
Does anyone know where to get the latest ECU and TCU (DCT) firmware updates? I currently have a 2016 F80 M3, still under warranty and wanting to get those updates done. Thanks |
02-19-2019, 07:53 PM | #3 |
Rep 984
02-19-2019, 08:31 PM | #4 |
Lost Motorcyclist
167
Rep 379
Can't answer specifically but when the dealer does a software update it updates everything. You can't ask for them to load the GTS DCT as part of it because it's not factory software for your car.
In saying, when Alex last logged on for me to do some loading he updated my GTS DCT load to the latest version compared to 12 months prior. Don't forget if you get a dealer update it will overwrite everything back to factory for your car. |
02-19-2019, 10:15 PM | #5 | |
Rep 984
02-20-2019, 07:08 PM | #6 |
Rep 357
I had a new transmission due to some early synchro wear and they performed a full software update (also a 2016) - night and day improvement in drive ability because of throttle improvements, steering weights, damper control in sport+ and traction control not being an on/off switch any more 😊
You can check your version of iStep by opening up the Vehicle settings on idrive, going to profile, doing an export to a USB key and then opening up the text file inside the folder on the key in notepad (or similar) on a computer. The version is very near the top. |
02-20-2019, 09:58 PM | #7 | |
Rep 984
02-21-2019, 12:16 AM | #8 | ||
Rep 357
02-21-2019, 10:05 PM | #10 |
Rep 984
02-21-2019, 10:06 PM | #11 | |
Rep 984
mfurse182.00 |
05-20-2020, 09:05 AM | #12 |
Rep 12
I am running a Stage 2 tune (BM3) and have done the EPAS, DCT, TCM, and Diff tune with the Thor Flasher on my non ZCP car. My service tech told me that there is an update. Anyone have any idea if I am better off doing the new update and then reflashing the car and then retuning? Would I just be overwriting the update when I tune it again, negating any updates? Anyone know if the Thor and BM3 tunes are modified versions of the latest BMW software or do they use an older version? Appreciate any help in advance.
05-21-2020, 04:50 PM | #13 |
Rep 133
I did the whole car update myself. Almost bricked the car but manage to fix it.
Most noticeable difference is the dsc, and dme. I had 2015 software. It's a lot more tame for dme. Felt detuned - but I have since put Bm3 on. For dsc was a huge improvement imo. It lets it rip for a second(s) before kicking in. Previously it constantly kick in which gets annoying. |
dhruva19.50 |
05-21-2020, 04:56 PM | #14 | |
Rep 133
If u have Bm3 applied then Bm3 would have taken a copy of your rom version. You will need to get Bm3 to reset your account so it copy's your new version of your rom and reapply the mappings/ parameters. |
dhruva19.50 |
05-21-2020, 05:12 PM | #15 |
Rep 12
Got it. I appreciate the help. I was notified by my tech that some new BMW updates will cause the cars DME to not be unlocked simply with BM3 like before. It requires removing the DME because they have not cracked the new software. Is this true? Btw this is not at a dealer, this is a professional bmw only shop.
05-21-2020, 09:03 PM | #16 | |
Rep 133
Only latest cars 2020 will require dme removal I believe. I updated latest software, reset Bm3 account, Bm3 reapply and unlocked dme no problem. |
dhruva19.50 |
