04-19-2019, 07:17 PM | #1 |
Rep 137
Oil level warning
I'm getting an oil level warning every time I start my car. If I test the level it is green right up to top and says ok. Any ideas what this could be?
04-19-2019, 07:56 PM | #3 |
Rep 137
04-20-2019, 01:51 AM | #5 |
Roll Tide
285
Rep 568
I miss dipsticks...
AW/SO - ED delivery 6/20/16
PCD - 9/1/16 |
04-20-2019, 07:59 AM | #6 |
Rep 137
04-20-2019, 09:13 AM | #7 |
Rep 62
Are you tuned? I ran into the same issue. I even went ahead and changed the oil level sensor which did nothing. After some thought I realized this started happening after switching maps. Reflashed the car and it was all good. Happened once more when map switching but reflashing fixed it again
trackymbf8243.50 Chris@VargasTurboTech1932.00 |
04-20-2019, 09:56 AM | #8 |
Rep 1,105
As always when some light pops up check the obvious things first. The number of threads here where people come and tell about an issue and then afterwards it is because they forgot to mention something. There are NO coincidences, if everything is ok for example and a light pops up after changing the oil this is NOT a coincidence peeps! How much oil was put in when the oil got replaced?
04-20-2019, 12:46 PM | #9 | |
Rep 137
Scrapenframe28.50 |
04-20-2019, 12:49 PM | #10 |
Rep 62
Awesome glad it Fixed it. Had me freaking out at first but now we know lol
04-20-2019, 12:56 PM | #11 | |
Rep 137
04-20-2019, 06:07 PM | #12 |
Rep 1,336
It's great u found the issue. The greater concern is if switching maps or flashing an update causes this what else are we not aware about that is screwed up in the process randomly.
Did you log a ticket with BM3?
04-21-2019, 09:19 AM | #14 |
Rep 137
03-04-2020, 12:43 AM | #16 | |
Rep 26
03-04-2020, 12:50 PM | #17 | ||
Rep 771
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
03-04-2020, 04:36 PM | #18 |
Rep 267
+1. It clearly tells you to turn the car off for 5 seconds before starting it. I’ve never had an issue and I switch maps regularly.
726whp/668wtq corn fed meth addict
08-11-2020, 05:55 AM | #19 |
Rep 4
09-30-2020, 05:31 PM | #20 |
Rep 33
i appear to be having the same issue, after I flashed a stage 1 map with bm3. Im going to flash back to stock and see if it goes away before i replace the sensor.
09-30-2020, 09:11 PM | #21 |
Who's da masta?
79
Rep 180
I just had the same thing happen, low oil level light came on a cold start. Turned the car off for a few seconds then turned it back on and the light was gone but the code was still there. Drove it to warm it up and measured green to the top. Haven’t changed the oil for 3k miles. Now the temperatures did drop to low 60s here from 80s, not sure if that would have anything to do with it. Could the oil level sensor be going bad? Been running my e85 Jordan tune close to 3 months now and about to switch it back to 93 oct tune for a full tank clean out. Weird it happened to someone else today also.
09-30-2020, 09:33 PM | #22 |
Rep 511
You know, you can actually (GT4) retrofit an actual BMW dipstick into our cars.
You'd lose the sensor/idrive function, though. Cheers!
///M Joy
