01-31-2018, 05:31 PM | #1 |
i build cool shit
579
Rep 712
Drives: 2018 Individual SMB F80 M3
Are the M Performance HAS and KW HAS identical?
Has anyone confirmed this yet? I've reached out to numerous vendors non of which can confidently confirm if the KW HAS is identical to the M Performance HAS besides the obvious color. I know they updated the KW HAS around the same time of release and I'm currently torn between spending 2x for what may be the same exact thing. If anyone has had both and can confirm noticing any differences that would be greatly appreciated.
02-01-2018, 05:21 PM | #2 |
Rep 508
Drives: 11'E90 / 18'F82
I'm curious too
02-01-2018, 05:38 PM | #3 |
Rep 1,496
Not gonna be the "YOU NEED TO SEARCH" guy but... found this with a search and it probably answers your question:
http://f80.bimmerpost.com/forums/sho....php?t=1384481
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
02-02-2018, 12:49 AM | #4 | ||
i build cool shit
579
Rep 712
Also the thread mentions the guy in the MP HAS gigantic thread who says he went from KW. He didn't post if he had the original or v2.
02-03-2018, 01:33 AM | #6 |
Rep 908
You can tell by the front perches. If they look similar to the MP HAS then that is v2 (I believe KW is black and purple). If they are brass colored with a bigger purple screw than those are v1.
09-15-2019, 11:31 AM | #7 |
Rep 3
Does anyone know if there is a ride quality different between the KW HAS and M Performance HAS? Spring rate differences? Would like to get the KW system and some spacers for the same price or less as the M Performance system.
09-15-2019, 12:59 PM | #8 |
Rep 4,106
09-15-2019, 01:00 PM | #9 |
Rep 3,804
I don't think the MP HAS spring rates are public, but just from testimonials of both kits, they are most certainly different. The KW seems to be more aggressive and rougher. Spring design is different. MP HAS ride quality is damn near perfect and highly recommended IMO.
09-15-2019, 01:06 PM | #10 |
i build cool shit
579
Rep 712
I had the first version of the KW kit back in 2015 and it was most definitely different. I've heard now the new updated version is the same but spring rates aren't confirmed last I checked.
09-15-2019, 02:22 PM | #11 |
Rep 3
Thanks for the reply! I've seen the newer version of the KW kit and it does look pretty much the same as the M Performance kit aside from the colors. Can't tell spring rates or other nuances through pictures though!
09-15-2019, 06:18 PM | #13 |
Rep 4,106
09-15-2019, 08:10 PM | #14 |
i build cool shit
579
Rep 712
I have MP HAS second time around. Much better than KW HAS was but like I said I had v1 in 2015 right when it came out. Not sure how much was the refinements between 2015 and 2018 M3 and the kit though.
09-16-2019, 10:35 AM | #15 |
Rep 3
Thanks for the replies everyone! I was also doing some more searching and I came across a huge thread and there as another guy who switched from KW to M Performance. He seemed quite pleased with the change. Sounds like M Performance is the way to go! Thanks again!
09-16-2019, 08:08 PM | #16 |
Rep 1,206
I read that mp has has nearly Identical spring rates to ZCP. Kind of a bummer. Would hope to firm up the ride. Lowering the car at this price point without an increase in handling seems foolish.
09-16-2019, 09:03 PM | #18 | |
Rep 20,741
Further, lowering the car does benefit handling even if the springs aren't stiffer. Lowering the car reduces the amount of weight transfer during cornering which increases total grip. On the other hand, stiffer springs do no necessarily translate to an "increase" in handling. As a general rule, a softer suspension improves grip while a stiffer suspension improves response. The fine art of suspension tuning resides in achieving the perfect balance.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 09-16-2019 at 09:09 PM.. |
Brickologic32.00 |
09-17-2019, 12:47 PM | #20 |
Rep 3,539
Drives: 328d Wagon, M2 Comp, i4 eD35
I wonder how many of the MP-HAS spring's coils are in bind at static ride height. I've seen companies (like Bilstein) use progressive springs, however all of the low-rate coils were bound already at static height. They're using the low-rate coils to keep pre-load during droop, performing the same function as a helper spring in a dual-spring configuration. It's possible then that since the MP-HAS spring has to be able to allow a lower ride height, that the final rate could be similar to ZCP rates, and reasonable since they probably wouldn't change the rate drastically while keeping the damping the same.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
09-17-2019, 06:45 PM | #21 | |
Rep 3,804
09-17-2019, 07:22 PM | #22 | |
Rep 1,206
I didn’t share an assessment. I said i read that the spring rates between the mp has and the ZCP are nearly identical. If you have facts that disagree then by all means share them. With that said, i saw tons of people say mp has improved the firmness of their civic. |
