07-31-2022, 10:38 AM | #1 |
Rep 152
Drives: BMW M4 and BMW M3 E46
OEM 666 rims with larger size tires?
I am currently have run flats oem tires on the 666 rims.
How much larger can I go? Would 275/30/20 front and 295/30/20 rear fit without any issues? |
07-31-2022, 10:40 AM | #2 |
Rep 708
Drives: E46/F15/GT4
Rears should be fine but you'll probably rub on the fender liner for the fronts.
07-31-2022, 10:56 AM | #3 |
Rep 152
07-31-2022, 11:37 AM | #4 |
Rep 320
I run those sizes on my M4 and I do not have any rubbing issues. It will also depend on the tires manufacturer because there are variances in width despite the numbers. I have PS4S FYI
Pauldunlop13425.00 |
07-31-2022, 12:56 PM | #5 | |
Rep 152
Do you have any pictures of yours with the wider tires? |
07-31-2022, 01:06 PM | #6 |
Sad ///M noises
4197
Rep 1,798
TractionControlDelete4595.50 |
07-31-2022, 07:46 PM | #9 |
Rep 152
08-10-2022, 01:23 PM | #11 |
Rep 828
All depends on your drop and spacer sizes. 275 front is ok if you only run no spacer or 5mm up front. 295 rear has no issues and also done and did and confirmed by many.
08-10-2022, 06:45 PM | #12 |
Rep 14
Drives: BMW 850i Convertible
Garage List 2021 Ford F150 Ligh ... [0.00]
2023 BMW X7 M50i [0.00] 2022 BMW M850i Conv ... [0.00] 2020 BMW M2 CS [0.00] 2018 Porsche Boxste ... [0.00] 2018 Mclaren 570S [0.00] |
I went 305's
I just installed 305's on the back of my M4 and it looks amazing. No drivability issues so far. Michelin 4S. Who needs spacers?
08-10-2022, 09:41 PM | #13 |
Rep 34
I have 295 on the back, fits perfectly. 265 up front, same thing.
Can't speak on 275 from experience in the front but it should fit. Here is a picture from the back with 295. Just like you're doing now, I spent some time on looking into this. The general takeaway for me is if you take the chart (attached link), look at the max recommended for the rim size and add 10mm, you'll get the rough max that will fit with a very high degree of certainty. Link: https://i.pinimg.com/736x/e4/7f/42/e...eb75b0b5f3.jpg |
TractionControlDelete4595.50 cobra2814112.00 |
08-10-2022, 11:25 PM | #14 | |
Rep 152
08-11-2022, 09:16 AM | #15 |
Rep 152
08-11-2022, 11:15 PM | #17 | |
Rep 152
How do you like them? Comparable to the Michelin? |
08-12-2022, 09:23 AM | #19 |
Rep 152
09-22-2022, 08:19 PM | #20 | ||
Rep 171
09-25-2022, 04:24 PM | #21 |
Rep 97
Hey guys, reading up...I'm looking to swap to mich AS4s with 265s in the front and either 295s or 305s in the back.
Will I have any benefits or issues with either the 295s or 305s? I'm trying to get my setup to about 600whp and want to make sure I'm putting down enough traction. |
