      08-20-2019, 01:05 PM   #1
MINERALGREY_F80M3
MINERALGREY_F80M3's Avatar
103
Drives: BMW M3 - F80
Removing KW EDC Cancelation kit
How's it going everyone!
My first post here since my recent purchase of a 15' Mineral white with carbon interior F80 M3!
Very excited to be apart of the community!
When I purchased the car I had some previous info about it from the previous owner. The issue I am having is that the car previously had KW V3 coilovers installed and returned to the oem EDC suspension. However, the shop left the KW cancellation kit connected and obviously it does not change settings when i press the EDC button.
I managed to find the cable from the top of the shock tucked away under some plastics, but since the KW module is connected I cannot disconnect and connect the oem cable, do I need to purchase the new connectors and re-pin them to work?
I am going nuts here because I cannot find a solution online.
Any help is appreciated!!
      08-20-2019, 01:46 PM   #2
Keebin
Keebin's Avatar
334
yeah you will need new connectors, i remember swapping mine when i did the v3 install with the delete. i know some one will chime in with the part numbers.
      08-20-2019, 01:59 PM   #3
MINERALGREY_F80M3
103
Ah awesome! I figured that would be the case, part # would be fantastic!
Thanks for the confirmation
      08-20-2019, 03:11 PM   #4
jd__m4
jd__m4's Avatar
415
Drives: AY M4
I'm guessing you're the fella on reddit from yesterday?
Is this what you're looking for? https://www.ecstuning.com/b-genuine-...c/31312284780/
      08-20-2019, 07:37 PM   #5
MINERALGREY_F80M3
103
Yes that was me!
Not quite, that part is intact and connected, the KW lot comes with its own connector that replaces the oem unit, similar to the one pictured below
The current plug that comes from the KW unit will not plug into the blue end of the oem unit
      08-21-2019, 07:13 AM   #6
MINERALGREY_F80M3
103
Updated last comment with picture of the plugs I believe I will need, but OEM version!
Thank you
      08-21-2019, 08:15 AM   #7
danniexi
danniexi's Avatar
Drives: 2022 F97 X3M Comp LCI
there are dozens of us
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
      08-21-2019, 08:38 AM   #8
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Originally Posted by MINERALWHITE_F80M3 View Post
Yes that was me!
Is this what you're talking about?
      08-21-2019, 03:50 PM   #9
MINERALGREY_F80M3
103
Yeap that's them!
Fortunately I've been speaking to the previous owner and he let me know he has the original plugs! I'm going to try and have them installed and will report back
Thanks all for your insight
      08-21-2019, 04:01 PM   #10
MINERALGREY_F80M3
103
Yeap that's them!
      10-06-2020, 02:50 PM   #11
PJDK
Drives: M3 F80, X5 G05, GT3RS
Anyone have a part number for the yellow plugs? Thx.
      11-17-2020, 12:24 AM   #12
Spun Crankhub
Drives: 15 F82 *SOLD*
They are part of the KW EDC delete kit. You can try contacting KW but their service and access to parts has been significantly hindered by the pandemic.
      09-19-2022, 12:42 AM   #13
smokeywokey
Drives: 335i
Thank you
sorry to open up an old thread but i’m in the same boat, my car has bags on it and trying to revert back to stock but i need OEM harness side connectors, were you able to find any? or am i just gonna have to snip both sides of each connector and wire it together like that
