Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      10-26-2020, 06:03 PM   #1
h_bakken
Drives: 2012 M3 (E93) Convertible
So I was taking a look around, there are a lot of bolts on the top of the shock tower. What sort of adjustability is there on the stock unit, any ability to adjust camber?
Also, anybody know the part number for this little dumb fastener that holds the rubber mat down. I almost broke it taking it off because it was... well I'm stupid.
      10-26-2020, 06:46 PM   #2
9M71
Drives: 2018 F80 M3 | 6MT
No camber adjustment on factory without camber plates unfortunately
      10-26-2020, 06:56 PM   #3
h_bakken
Yeah that's what I figured given all the talk about camber plates. Why is such a complex construction then? It must do something is it just for castor?
      10-26-2020, 06:58 PM   #4
9M71
This should explain it
fanatic11018.50
SYT_Shadow11478.00
minn1914021.00
CanAutM321115.00
      10-26-2020, 07:11 PM   #5
h_bakken
      10-27-2020, 12:03 PM   #6
Gomeler
Drives: '16 M235iR, '16 M4 GTS
There's a strut-tower brace plus the carbon fiber v-brace plus the strut tophat all stacked in/on the strut tower. Bunch of components that want to be real stiff, so lots of bolts.
h_bakken148.50
      11-24-2020, 12:56 PM   #7
rcompound
Trackwarn
rcompound's Avatar
97
Drives: 2016 M4 GTS
This is your camber solution.
https://f80.bimmerpost.com/forums/sh....php?t=1777830
h_bakken148.50
      12-12-2020, 05:57 PM   #8
rcompound
Trackwarn
rcompound's Avatar
97
Drives: 2016 M4 GTS
Camber Solution
I moved from the GC plates to Millway plates. Sturdier construction, larger bearing (same size as OE) and works with the factory/KW hardware.
https://www.millway.se/camber-plates-m4-gts-f82.html
The good stuff.
Appreciate 6
irunalot1518.00
JimmyS70.00
Lienrocs701.00
h_bakken148.50
Gomeler500.00
      12-13-2020, 07:27 AM   #9
Studntloan
Studntloan
581
Drives: M4 GTS / E30 M3
if anyone needs camber plates I can get kw specific plates for the gts, they ride like stock, no banging around etc, Pm me!
h_bakken148.50
      12-17-2020, 12:51 PM   #10
h_bakken
There is another option out there which was actually recommended by the shop that I contacted in Austin Texas. Shop has a very good reputation and they say that they think these are the best on the market.
https://vorshlag-store.com/products/...31575223631934
