      12-19-2023, 11:54 PM   #1
Hamm
Drives: '16 BMW 340i & '13 Jeep JKU
Questions regarding potential purchase with possible spun crank hub
I'm looking into a 2017 M3 with a possible spun crank hub. Car has 55k miles and is a pretty good price. Problem is- it's not local to me (about 4 hours away) so I can't just go look at it. Car was putting down about 540hp when it spun. Seller doesn't really seem to know a whole lot, so I'm curious if there's a way to confirm it's just the crank hub. Seller said the cylinder 1 timing is off by .8 but sounds healthy when running (but is rough when getting out of 1st and 2nd gear). Price is good enough that I could pay to replace the crank hub, but not an engine replacement.
      12-20-2023, 12:20 AM   #2
Jbonly21
Jbonly21's Avatar
Drives: Bmw 15 F80, 2011 X5 35i, E46 M
If you can verify what he saying is true then go for it. How does he know how much the timing is off but yet doesn’t know much about what’s wrong with it? Also if they check the engine and found out that only the timing was off, which is a easy fix, why didn’t he just had it fixed why it was in the shop? It’s your choice to make, good luck.
https://youtube.com/user/Jbonly21
      12-20-2023, 12:20 AM   #3
headstart101
Drives: 2016 MG M4
You are basically buying a car with a blown engine. If the price of the car doesn’t cover an engine replacement, I would look elsewhere.
alex23642873.50
      12-20-2023, 12:29 AM   #4
Hamm
They sent me a data log that shows the timing on cylinder 1 being off by .8. I tried to upload a picture but couldn't figure out how. The other cylinders are reading perfect.
      12-20-2023, 12:32 AM   #5
Hamm
I don't think it's been to a shop. I think it spun then they parked it and are now selling it.
      12-20-2023, 05:00 AM   #6
AlmondJayRoM3
Drives: 2016 M3
Sounds like a load of BS. I’d stay away or offer a price to account for a full engine replacement. You don’t tune a car a like that, then claim that timing is off by .8 and claim not much is known. Unless you have some way of verifying what the issue is, you are taking a gamble.
Jbonly211081.50
      12-20-2023, 05:52 AM   #7
Jakester
Drives: F82
Spidey sense is tingling, I'd stay away from that one.
Seller is not telling you everything they know and are trying to get out from under a blown engine with minimal financial damage.
      12-20-2023, 10:56 AM   #8
Hamm
Thanks for the help everyone. I knew the answer before posting, but figured it was worth asking anyway. I'll keep an eye on it and see how low the price gets.
      12-20-2023, 11:26 AM   #9
G35POPPEDMYCHERRY
G35POPPEDMYCHERRY's Avatar
Drives: F80
if you don't know how to rebuild the engine yourself....which you don't since you are asking on this forum....you better expect a complete engine rebuild or drop in plus labor factored into the price let alone a car that has been beat the fuck up
hard pass
      12-20-2023, 03:24 PM   #10
theweebabySeamus
I don't believe for a second that the seller doesn't know much about the issue, whether they act like it or not.
If you can afford to replace the engine out of pocket, then maybe. If it doesn't need it, even better. But I would plan for the worst and base your decision off of that.
      12-20-2023, 05:18 PM   #11
NickyC
NickyC's Avatar
17485
This sounds like a horrific idea.
JTM09385.00
      12-20-2023, 05:29 PM   #12
N1rve's Avatar
2019 BMW M4  [9.63]
The S55 is an interference engine. A spunk crankhub can also lead to bent valves.
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      12-21-2023, 07:51 AM   #13
hC1001
Drives: E36 M3, F80 M3
As others have said, prepare for a rebuild and go through with it if the price is right. You could be lucky with just a retiming and crankhub replacement or it can cost 3 times more for a rebuild.
      12-21-2023, 10:24 AM   #14
Hamm
hard pass
Indeed I do not know how to rebuild an engine myself.
Apparently, the car was purchased in September. They threw an exhaust and a tune on it and drove it until the crank hub spun.
I knew this was the correct answer from the beginning, but wanted to get feedback anyway.
Makes sense.
I'm going to keep an eye on it and see how low the price gets. If it gets down to $20k or so, I might have to reconsider it.
Thanks for the help everyone! What I was hoping is someone would read this and say something like "that doesn't sound like a spun crank hub" that sounds like "(insert much less severe issue that is easily fixable)" here. I'm looking in the X3 M40i territory, but figured if I could pick up an M3 at a good price why the hell not.
      12-21-2023, 11:05 AM   #15
theweebabySeamus
Makes sense.
In that case, I'd pass. Guy got it and beat on it and is trying to get out from under it.
