INDustry distribution
      09-29-2016, 08:11 PM   #1
m3f80sf2ny
Drives: 2016 M3
Pad deposite vs warped rotor
I have read a lot of comments about the true cause of brake vibration being pad deposits instead of warped rotors.
So my questions are:
1) In practice, how can one reliably distinguish between pad deposit from truly warped rotors? Supposedly pad deposits also result in thickness variation?
2) What kind of driving or other mechanical defect would cause rotors to warp?
      09-29-2016, 10:13 PM   #2
TRZ06
TRZ06's Avatar
Drives: 16' M3
I don't know, but I'm super pissed at BMW for f@cking up the steel brakes on this car.
They did it right in the E90/92, those were the best stock brakes I have ever had on a car. They were rock solid with no issues and grip for days.
Maybe they dumbed down the F80/82 brakes because of the CCB option, I don't know, but they used to be awesome. Now they suck.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels)
15' Audi S4
13' Audi TTRS (APR stage 1, MSS springs)
09' C6 Z06
08' M3 Interlagos Blue: 6sp, Tech.
hdubf80122.50
      09-29-2016, 10:28 PM   #3
CanAutM3
CanAutM3's Avatar
Drives: 2019 M4cs
2019 BMW M4cs  [0.00]
2018 Audi RS3  [0.00]
The brakes on the F8X are the best of any M3(4) thus far. I've owned an E46, an E92 and now an F82. All are/were tracked extensively (16~20 track days per season). I can attest the the brakes on the F8X are better than the ones I had on my previous ///Ms.
///M4cs 2019 F82 Lime Rock Grey
MPE / CF Mirror caps / MP-HAS / GC Camber plates
      09-29-2016, 10:33 PM   #4
CanAutM3
CanAutM3's Avatar
Drives: 2019 M4cs
The best and fastest way to find out if it is uneven pad deposit that is causing the shudder, is to install some abrasive pads for a few days to scrub the deposits off the rotors. If the shudder progressively goes away, then it is indeed pad deposit.
Just look at the size of those rotors. Imagine the stress needed to actually get them to warp. Maybe an intense thermal stress could warped them, such as splashing them with water when they are red hot. But even then...
      09-29-2016, 10:36 PM   #5
TRZ06
TRZ06's Avatar
Drives: 16' M3
I disagree. They muffed up the pad or rotor compound. They don't play nice together.
In the E90/92, they played very well together, no matter how hard you used them.
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
      09-30-2016, 08:27 PM   #6
m3f80sf2ny
Drives: 2016 M3
I upgraded from OEM to DS2500, but apparently it wasn't enough to scrub off the deposits. I will be upgrading again to RS29 and hopefully that will be more effective.
      09-30-2016, 09:38 PM   #7
Jockey
Jockey's Avatar
Drives: F80 SS/SS M3
Wow, you really have nothing good to say about this car.
You are also the only person I recall who thinks the brakes on the E9X were better than this iteration.
      09-30-2016, 10:02 PM   #8
TRZ06
TRZ06's Avatar
Drives: 16' M3
I am just honest in my opinions. For the cost of this car and how's it's billed, I expect certain things to be done right.
The pad / rotor materials don't go well together, which causes groaning and vibrations.
The suspension has sloppy rebound and doesn't give confidence.
The chassis has poor traction and is undertired.
The traction control / stability control system is very weak and intrusive.
These are ALL things that should be a non-issue in a $80k+ M car. I think I have every right for its price point to be pissed.
I'm not saying I hate the car, but they messed up a lot of key things.
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
hdubf80122.50
Wywrot11.00
      09-30-2016, 10:08 PM   #9
Jockey
Jockey's Avatar
Brakes, suspension, chassis, traction control. Gee, anything else.
      09-30-2016, 10:51 PM   #10
TRZ06
TRZ06's Avatar
Drives: 16' M3
No, that's it.
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
      10-01-2016, 04:55 PM   #11
hdubf80
hdubf80's Avatar
Drives: 2015 F80 ///M3 AW/SO/DCT
He's right tho. Especially for M division. I haven't heard these complaints with the c63's
      10-01-2016, 05:08 PM   #12
Jockey
Jockey's Avatar
Well damn, the previous generations of M cars must've really been bad since this model is an improvement over them.
      10-01-2016, 05:58 PM   #13
TRZ06
TRZ06's Avatar
Drives: 16' M3
The competition wasn't as fierce with the last generation, so it was clearly the best choice back then, so expectations were lower.
Things have changed.
All the issues I noted, with the technology that's out there now, should not exist.
And the problem is, the money it costs to fix those issues, is not cheap to do.
It's still cheaper for me to fix those issues with aftermarket, then taking the deprecation hit and starting over, but still the point is I shouldn't have to spend the money in the aftermarket in the first place.
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
      10-01-2016, 06:04 PM   #14
Jockey
Jockey's Avatar
I guess you should've gone for test drive then and all of these inadequacies would have presented themselves.
      10-01-2016, 06:08 PM   #15
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
Are you joking? Why don't you sell it and buy another TT. You seem to hate everything about the F80.
      10-01-2016, 06:10 PM   #16
TRZ06
TRZ06's Avatar
Drives: 16' M3
Don't get all but hurt.
I don't have money to burn to take the deprecation hit.
These are my opinions.
I don't hate the car, I just think BMW dropped the ball in a few key areas. And I have no problem pointing that out, call it constructive criticism
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
Wywrot11.00
      10-01-2016, 07:00 PM   #17
Jockey
Jockey's Avatar
There is nothing constructive about your criticism, that's why you get called out on it.
      10-02-2016, 09:42 AM   #18
TRZ06
TRZ06's Avatar
Drives: 16' M3
Ok Einstein...
Tell me, on a test drive how am I going to know that in 1000 miles the brake material doesn't work well together and causes vibrations.
How am I going to know that the traction/stability control is intrusive.
How am I going to know how the suspension is going to react to various conditions.
How am I going to know traction is going to hard to come by. All new tires are slick as they have the release mold on them still.
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
mrduder441.00
      10-02-2016, 10:12 PM   #19
hdubf80
hdubf80's Avatar
At some point bmw forgot to compete with the rest of the major brands and thought about just selling units. These issues aren't present with let's say ferarri because of the constant competition from lambo or other brands. BMW thought it would be the benchmark and would not be contested but unfortunately the other brands have stepped up their game and are knocking bmw out of the top spot. These aren't my opinions just the majority of the reviewers that publish articles. (i.e motor trend, carfaction, autocar, etc) I've started a thread on the break issue and bmw is aware and I heard changing the pads. I'm not qualified enough to talk about suspension and chassis but Cadillac has beat them there. And the DSC is terrible. It's either all or none. Even the c63's has them beat there. These are facts not just opinions. The comp pack should have been the original version and the ZCP even more competitive. We should never lose to a Cadillac smh.
      10-03-2016, 12:08 AM   #20
F3IGHTY
F3IGHTY's Avatar
157
I completely agree, I came from an track prep'd S2k with more tire than a F80, and the most aggressive pads from various manufacturers, running within a couple seconds of local track records for my class. I am very impressed with the stock F80 setup and its heat capacity straight from the factory. Of course its not perfect, and theres plenty of room for a more aggressive tire and pad, but the car is well equipped for a street car.
I've been reading people complaining about pedal travel too in other threads, this has much more to do with the brake master cylinder bore size and accompanying booster than the pad compound. Even if you slap on a gnarly pad, you'll still end up using the same amount of stroke for equivalent force. If you want the pedal to be rock hard at the top of the stroke, get a larger bore size, and don't complain about lack of modularity later.
Yup, to answer OP - "It's always pad deposits"
      10-09-2016, 09:05 PM   #21
m3f80sf2ny
Drives: 2016 M3
I am really hoping it's just pad deposits.
Last time the vibration didn't go away after 3 weeks of street driving. Then I went to track again so the wait will reset...
brake pads, rotor
Copyright ©2000 - 2020, vBulletin Solutions Inc.
