08-02-2020, 07:24 PM | #1 |
I Drag Race My Track Car
200
Rep 226
Airbox Modification Tests
Just curious if anyone has done some tests with different air intake configurations in regards to tuning/logging/dyno data. I see manufacturers claim one thing then private dyno sessions claim another. So I am looking at 3 different air intake configs so far and comparing the same three points of data in different conditions. IAT, Boost and Wastegate duty cycle. All in the same gear, on the same road at the same RPM.
Has anyone tried modifying their stock airbox for giggles? I know on the n54s people had luck with opening up the bottom of the boxes so more air could get into the filter when the car was not moving as fast. Seeing as I am focused on drag racing more and more, I cut a series of holes in my bottom airbox to research any differences in the data. Three configs (all using Macht Shnell Air feed Scoops): OEM with BMC Filters, Injen evolution Intake and OEM modified with Drop ins. Injen Evolution: Average DRAGY 60-130 = 7.7 IAT: 84 | 86 | 82 Boost: 23.2 | 23.2 | 23.1 WGDC: 92.4 | 93 | 93.4 OEM Intake with Drop Ins: Average Dragy 60-130 = 7.5 IAT: 95 | 102 | 100 Boost: 23.2 | 23.1 | 22.8 WGDC: 91.1 | 92.9 | 92.3 Modified Oem Intake with Drop ins: Average Dragy 60-130 = 7.4! IAT: 75 | 90 | 90 Boost: 22.6 | 23.1 | 23.2 WGDC: 88.5 | 90.6 | 90.8 100-200kmh 6.43, 6.11, 6.04 CTS INTAKES Average Dragy 60-130 = 7.38 (should add weather started to cool) FINAL MODS CTS Intakes + Air Feeds + Fully Catless Straight Pipe Exhaust Average Dragy 60-130 = 7.1 FINAL FINAL MODS = CUSTOM TUNE, AIR FEEDS, DROP INS, MODIFIED OEMS Average Dragy 6.5-6.7 60-130 Update 11/21 Broke stock turbo 60-130 and 100-200kmh world record at 6.3 and 5.40 using final mods version above. Conclusion: Adding one more variable to study was "MAF Actual Channel." Using 6000rpm in 4th gear WOT as a baseline, 40 logs were averaged total with 10 from CTS, 10 from Injen, 10 from OEM and a separate test of 10 from OEM Custom tune. Oem intake 4.4 average higher at this range. However, it is important to note it was rare to find this channel being LOWER with oem set up at this range compared to aftermarkets. Even in more adverse conditions and higher DA the oem had higher MAF readings (placement of maf or indicator of flow??) V DYNO Logs and MAF readings at given rpm same gear same load indicate best performing set up to be OEM with DROP ins with air feeds and cut out lower sections. WGDC on 29psi to 25psi @redline is the same in winter as MHD stage 2 was at 4-5 less psi with 2 other aftermarket intakes. V Dyno reports a current 610-630whp dynojet number. Car traps 133-136 depending on DA, temp and weight. MHD ots tune logs report 552whp on VDyno once calibrated correctly. EXACTLY what car dynoed on real dynojet on MHD 2+ e30. Current tune dyno results to follow soon. Side NOTE: VANOS TUNING DRASTICALLY INFLUENCES WGDC AT CONSTANT BOOST PRESSURES. For instance, 23psi with 8* IN Vanos Degrees could be 88% WGDC, whereas with 3* (more aggressive overlap) could be 95%. All averages were taken on the same tune prior to custom tuning. Theory: Integrated velocity stack in OEM intake allows greater airflow over 3" mandrel or smooth tubing. Surface area of filter may be larger. I need to get my hands on eventuri now to see if there truly is a higher flower air intake set up.
ProSpoolFreaks Tuning E85
CBC Squad Last edited by Twistm4; 11-21-2021 at 12:45 AM.. |
18
so_f80m395.50 Shadow2121.00 guess2098516.00 whoop_ass355.00 bmwmdistrict908.00 TakeOne352.50 Detoxified204.50 ntg442888.50 EricVR4603.50 PhatLyfe985.00 AlterZgo1537.50 Dark-Yoda25.50 irunalot1518.00 m3elmo49.50 McBobby Jr212.00 deli333145.00 NORAGRETS440.50 BMW DIY Guy3070.00 |
08-04-2020, 04:31 AM | #3 |
200
Rep 226
So I got on the dyno today! Curious to see the differences between e30 2+ and e85 custom tune. My buddy with Cary e85 is going to same low reading dyno tomorrow and I can't wait to see his numbers.
The air cuts seemed to further drop the average but not by much. My iats were quite hot on the dyno after first pull but sat around 16-20* over ambient on the drive there. |
08-04-2020, 02:02 PM | #5 |
200
Rep 226
Its not much to look at. Dude couldn't get the tach wire hooked up. It was 85* and humid in an outside garage shop. No real fans for air flow. He also mentioned his reads about 4-6% low. So this is 21.5psi and 12.5*. On the street it sees 24-26psi and 13.5*. We think this number is more like 572 in this heat, and then around 6 ish with STD correction.
But hey if people ask Im gonna tell them it makes 550 because thats what it did xD
CBC Squad |
08-04-2020, 02:34 PM | #6 |
Rep 352
Lots of power, thanks for posting, i have worked for a race teams and we always put DEI gold foil tape around our air boxes and air intake tubes to help lower ait's 👍
08-05-2020, 05:09 PM | #8 |
Rep 2,152
Sorry complete newbie here so I am a little confused
So the full intake had lower intake temps than stock ran slightly better boost but the waste gate duty cycle was higher thus making it slower? I presume the lower the WGDC the better? |
08-05-2020, 05:59 PM | #9 |
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
your tests data are much more clear and easy to read than other BIG intake companies out there. we need to see the data like yours. instead they are feeding us some fancy pictures of air flow and whoknows dyno graph!
08-05-2020, 10:45 PM | #11 |
200
Rep 226
The higher iats was because it was much hotter outside when the tests were taken. Typically WGDC rises with heat. Cold air is much easier to compress than warm for instance. So yes the oem intakes actually performed SLIGHTLY better. I am finishing up my modified airbox readings today!
CBC Squad |
08-05-2020, 10:48 PM | #12 |
200
Rep 226
Sometimes its hard to tell sarcasm in text. Are you trying to joke or actually serious? lol. If I could do it over again I would have left the bottom part in tact and cut just the sides and front out. Basically catching the air thats passing through the headlight area etc. Can also take out weather stripping for more airflow but not really gonna make a difference. I just used a cheap dremel tool and cleaned up with files and sandpaper. I could make it look much neater but would just take more time.
CBC Squad |
08-06-2020, 01:23 AM | #13 |
200
Rep 226
Wow guys. Just finished up my results with modified airbox. I am actually stunned at the results!! I will update post with new findings!
CBC Squad |
08-06-2020, 03:15 PM | #15 |
200
Rep 226
Take about 15-20 off IAT
CBC Squad |
08-06-2020, 03:16 PM | #16 | |
200
Rep 226
Also, if all this doesn't matter how do we explain the dragy improvement? One even in worse conditions?
CBC Squad |
08-07-2020, 02:26 AM | #18 |
Rep 518
How I tested the airbox was comparing the GT4 race car air box components with the road car and it's all the same. That tells me the stock air box works efficiently enough to leave it alone The GT4 parts list also tells us it has catless downpipes to confirm the primary cat delete likely does reduce the waste gate duty cycle and performs more efficiently than stock (catted) downpipes.
08-07-2020, 03:22 AM | #19 | |
200
Rep 226
..and reporting patterns with certain air intakes is.. claiming to be a tuner? You are quite a gem. Last edited by Twistm4; 08-07-2020 at 03:28 AM.. |
TractionControlDelete4588.50 |
08-07-2020, 03:29 AM | #20 | |
200
Rep 226
08-07-2020, 03:31 AM | #21 |
200
Rep 226
I have a cts intake on the way. I am going to create my own heat shield out of 1/4" sheet metal basically to mirror the MST intake and test + dyno + dragy.
08-07-2020, 05:21 AM | #22 |
Rep 389
Drives: 18 BMW M2LPower
great, is good make all kind of test. a few years back in vey hot weather we had similar results them upgrade to front mount cold air intakes and reduce 0.20sec 100-200pkh.
keep it up !
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
