| 05-25-2025, 04:50 PM | #1 |
Rep 267
Vargas Crankcase Breather s55
does anyone have this product and does it fit? it’s designed to vent extra crankcase pressure and not let air in. i tested with a vacuum hose and it definitely works.
however i’m having trouble installing it. the instructions say using the oem oil cap gasket but that’s already installed on the vargas product. it’s supposed to fit the s55 based on their website. is there something i’m missing and does anyone have this product and how did you guys manage to install it? Vargas Crankcase Breather
F82 Liberty Walk M4
ABPerformance |
| 05-25-2025, 07:36 PM | #2 |
Rep 1,144
I have BMS catch can, works great. Other folks use Mishimoto catch can and both work great, haven't much about using this set-up. The issue with this filter set up is the timing chain will sling oil up/vapor around that front area of engine/valve cover and that filter will get saturated quickly. To me the best option is stock valve cover with Mishi or BMS catch can.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | Infinity Design | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
| 05-26-2025, 04:06 PM | #4 |
![]() 788
Rep 2,714
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Stay away from Vargas that’s my advice
2017 F80 ZCP BSM - InkedCustoms.PureStage2+.ActiveAutowerkes.AR-Design.BootMod3.ApexTitanium.ProjectGamma.RW Carbon.UCP.UUC.Dinan.MachtSchnell.TMS.Eventui.aFe.
RIP - E82 135i - 7/7/2021 ![]() |
| Bookmarks |
| Thread Tools | |
