      05-28-2025, 01:22 PM   #1
dermann
Drives: BMW 135i BMW X3MC, F80 M3
single turbo f80 m3 o2 sensor codes
So ive been working on this single turbo m3 and I cant seem to figure out what the problem is. I am getting codes for o2 sensors (pictured) even though I moved both bank 1 primary and secondary to the downpipe, plugged the holes on the manifold, and loaded a base single turbo tune with the mhd single bank fueling option enabled. I have no idea what im doing wrong but the car has 160 hp and when I give it more gas it throws a code with the knock sensor. I have the mpr1200 kit and I have a motiv reflex paired with a mac solenoid. Is it a tune thing or are the o2 sensors bad? Im at a dead end so any help would be greatly appreciated.
      05-28-2025, 01:32 PM   #2
dms-01
dms-01's Avatar
1245
Drives: 2018 F80 M3
Just guessing but google returns this:
https://f87.bimmerpost.com/forums/sh...4&postcount=27
Seeing as how both of yours are throwing codes maybe it is just lack of complete connection at the harness? That is if its not tune related.
      05-28-2025, 01:47 PM   #3
dermann
Just checked. Mine are both fully in. I know for sure because I have messed with them when I did catless downpipes on the car and I never had sensor issues. My only guess is those codes are referring to the bank 2 sensors which are not in the car, due to single bank fueling.
      05-28-2025, 03:01 PM   #4
b_w.
Drives: ST F80 M3 GT More 6 SPD, F90 C
I am replacing mine yearly. FCP Euro FTW.
      05-28-2025, 05:55 PM   #5
pxscu
pxscu
pxscu's Avatar
29
Drives: 2015 BMW M3
I believe I had to get one of my sensors I wasn't using coded out even with single bank enabled. But I've burned my downstream O2 out twice now. Enabling cold start to see if that helps anything..
2015 F80 M3 - BigBoost 8474 EFR Single Turbo / EU5 Injectors / Precision Stage 3 Brushless LPFP / Dorch Lift Kit / Wagner Cooler
https://www.instagram.com/pxscu/
      05-28-2025, 09:15 PM   #6
Zoomz_7
Zoomz_7's Avatar
2015 BMW M3  [9.75]
This is my 3rd time killing my secondary o2 sensors on my single turbo setup. Any luck with enabling cold start? Mine is also disabled.
      06-04-2025, 04:30 PM   #7
pxscu
pxscu
pxscu's Avatar
29
Drives: 2015 BMW M3
so far so good.. but I just put a new one in and am testing the theory so not enough time yet
