06-19-2018, 10:53 PM | #1 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Dinan Tension Strut Ball Joint Kit
For those running a the Dinan Tension Strut Ball Joint Kit or similar, do you have any tips for the install? Is an alignment necessary after the install?
/// M3 Last edited by Brasko; 06-22-2018 at 08:00 AM.. |
07-01-2018, 09:40 AM | #4 |
Rep 122
I have a similar setup from fall line and you’ll want to torque down the bolts at ride height not full droop...and the monoball setup I have is a bit louder and harsher over bumps and road imperfections but not horrible, they also click a bit when turning the wheels but the oem’s do this a bit as well, the solid ones are just a lil louder and do it more...definitely less front toe deflection at the limit of traction and under braking as the stock ones are made to toe in at the limit and absorb some shock over big bumps imo...good luck happy modding lol
ball joint, dinan, f8x, tension strut |
