01-01-2017, 02:26 PM | #1 |
Rep 1,095
JB4 Hesitation
So I had the dealer change the plugs. 5k miles later I'm getting sputtering doing wot from 4k rpm. Map 1 has a slight sputter and map 0 runs smooth. Today I got misfire cylinder #1 and #2 for the first time on map 2. I don't know what to do since map 1 and 2 isn't useable anymore.
Plugs have 5k miles on it. Should I change coils? Car has 39k miles. I have short logs when the sputtering occurs. It happens right after I floor it then 5 secs later it pulls.
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
01-01-2017, 06:13 PM | #3 |
Rep 1,095
Plugs have 5k miles on them. Should I replace it since I have to gap it?
01-01-2017, 06:23 PM | #5 |
Rep 1,095
How long should the plugs last if gapped properly?
01-01-2017, 08:13 PM | #6 |
Rep 4,265
Sounds like the experience I had on my e92 N54. Get a flash tune. JB4 is junk IMO
The Choosey begger71933.50 euro*1657.50 |
01-01-2017, 08:40 PM | #7 |
Rep 1,498
Drives: 2017 MB C63 S AMG Coupe
Plugs. Spark getting blown out.
Take them out and look at them to see if any have a larger then normal space, but gap them down to .18
2017 MB C63 S Coupe - DINAN | MODAL WORKS
retired: GranTurismo MC, Giulia Quadrifoglio, B8.5 RS5, Q60 RedSport, e82 135, F80, e92 M3, e90 M3, (2) e92 335, B8 S4, C209 CLK55 AMG, e46 330 |
///F80M3654.00 |
01-01-2017, 08:41 PM | #8 |
660
Rep 1,059
I don't disagree that a flash tune is the only proper way to tune, but ignorant blanket statements like yours are just dumb. It's safe to say the JB4 is not junk - results based threads here and other forums confirm that. Try not to let the anonymity of the internet allow you to post stupidity.
psedog482.50 |
01-01-2017, 09:20 PM | #9 | |
Rep 4,265
01-02-2017, 07:51 AM | #10 |
Joint Chiefs of Staff
4916
Rep 115,980
Could be plugs. You posted photo of the logs so I can't open them in the JB4 interface to check your settings and other data. Normally you'd post the CSV log files.
Mike |
01-02-2017, 08:03 AM | #11 |
Libertarian
71934
Rep 4,035
///M4ster Yoda4602.00 |
01-02-2017, 08:06 AM | #12 | |
Gone Fishin’
7318
Rep 12,125
Just a few months ago Master Yoda was posting he was putting JB4 on his M4. Most of the time JB4 issues = User error. |
01-02-2017, 08:10 AM | #13 |
Rep 4,265
Yes. I wasn't trying to be a jerk off with my posts last night. I learned my lesson with the N54. Why put a device on a 70-90k car that makes it run inconsistent and shitty half the time. I ended up going Cobb Protune on that platform. Car was a beast. OP I recommend doing the same here.
01-02-2017, 08:18 AM | #14 | |
Libertarian
71934
Rep 4,035
Of course you're not gonna mention times when Terry's cars or other members cars had problems at those events. |
01-02-2017, 09:21 AM | #15 |
Rep 246
I'm running JB4 for 2 yrs without any problems. With E30/E50/E85 or meth is the best buy and the fastest on the 1/4 mile.
I have now the stage ecu tuning and running jb4. This combo is the best. Win-win situation.
M4 F82, MG, stage 2+, ER catless DP, Akra, Armytrix, BMS intake, ER charge pipes, Ohlins R&T, GTS/CS hood, GTS flash, EDC CS, 763M CS rims, LCI taillights and LCI LED adaptive headlights
M5 F10, Singapore grey, stage 2 E92 335i RB upgrade turbo & FBO |
01-02-2017, 09:46 AM | #16 |
Rep 250
Like there hasn't been a problems with flash tuning lol .. there always will be a problems JB4 or flash tune etc .. some cars have them some don't ..
01-02-2017, 10:01 AM | #17 |
Gone Fishin’
7318
Rep 12,125
Im actually taking my car in next week to have the ecu pulled and sent to Autotalent for BM3. Not sure if Ill leave thr JB4 on as well or not. What I can say is to call the jb4 junk is laughable.
01-02-2017, 11:24 AM | #18 |
Rep 190,797
Op,
Recommend you post longs instead of screenshot and as mentioned above make sure plugs are gaped correctly
01-02-2017, 12:41 PM | #19 | |
4916
Rep 115,980
Mike |
01-02-2017, 02:21 PM | #20 |
Rep 655
Drives: 2015 F82 M4 Blk on Blk, DCT
Love my JB4.
Have never had any problems with it over the last 1 1/2 years and various mods/setups on my car.
2015 F82 DCT M4. Max PSI Built Motor, Ported head, Full Bolt Ons, Upgraded fuel system, Motiv Reflex and flex hardware for flex fuel, Max PSI Crank Hub Fix, Pure PS2+ Turbos, SSP Spec X clutch, xHP Trans Flash, DSS Axles. Custom Ecutek tune by Ian @bend calibration. 780whp & 700+ ft lbs torque, 18" HRE R101s.
01-02-2017, 02:52 PM | #21 |
Rep 370
01-02-2017, 03:05 PM | #22 |
Rep 1,498
JB4: Great for making high boost
Flash: Great for everything else Remember, the JB4 is more so used as a boost controller since it cannot change any of the mapping of the car. Because our cars are "smarter" then normal cars, the JB4 works well with it since the car understand and makes the appropriate changes. The JB4 isn't "junk" but I cannot say it is problem free. Personally, I ran much more consistent at the track and at the dragway with a flash tune (VF)...fastest run with JB4 was 11.8, fastest run with hex was 11.1...and yes, exact same setup for both runs. Can go into the differences I felt going down the track, but this isn't the time or place for it, PM me if you want to hear it. Take it for what it's worth though. I also felt that the car was searching for the correct boost with the JB4, whereas with flash it just knew to boost to 26psi. Again, a flashing advantage. But...this is why the highest powered cars run both. JB4 handles boost, flash takes care of everything else so that the car responds to the added boost even better. Everything that I stated has been said in 10000xxxx other posts lol
Sleeper659.50 schnell1982345.00 |
