11-22-2019, 12:17 PM | #1 |
Rep 884
US Millworks Front Plate Bracket Position
I installed the US Millworks Front Plate Bracket yesterday, and while reversing today, I noticed that it randomly triggers my front parking sensors.
I don't think the sensors are that close (see below circled in orange). The bracket is attached so that the plate is positioned as far left (when looking at the car) as possible. Is my only option (to avoid the sensors) to adjust the frame so that the plate is positioned higher? I'm not sure I'll like how that looks. Any thoughts on positioning (and not on other alternatives to the Millworks product) would be much appreciated. Thanks.
Previously:
11-22-2019, 12:58 PM | #3 |
Rep 1,930
You have to make the prong so that with the quick release it slides in from the right to left.
If you position the prongs and slip in the bracket from the top down it will trigger the sensor everytime. |
11-22-2019, 01:02 PM | #4 | |
Rep 884
I currently have the attachment, such that the plate bracket slides right to left to attach, and not up and down, i.e., the quick-connect pins are vertical. I think this is what you are indicating I should do, correct?
Previously:
11-22-2019, 01:05 PM | #5 | |
Rep 1,930
Only time it sometimes goes off for me is when it rains. |
11-22-2019, 01:09 PM | #6 | ||
Rep 217
Drives: 2023 M3 Comp Xdrive
11-22-2019, 01:13 PM | #7 | ||
Rep 884
Currently, mine is at the top right. So, I'm guessing your plate is sitting further up than mine, distancing it a bit more from the sensor. Can you post a picture installed to confirm. Thanks!
Previously:
11-22-2019, 01:20 PM | #8 | |
Rep 1,930
RElias21562.50 |
11-22-2019, 02:20 PM | #9 |
Rep 516
NY & NJ front mount plate install https://f80.bimmerpost.com/forums/sh....php?t=1639370
2010 Jet Black E90 ZCP DCT - RIP
2011 Jerez E90 ZCP DCT - Sold 2018 Avus Blue F80 ZCP MT |
11-22-2019, 02:49 PM | #10 | |
Rep 884
Previously:
12-04-2019, 06:00 PM | #11 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
07-31-2020, 02:18 PM | #12 |
Rep 304
07-31-2020, 04:10 PM | #13 | |
Rep 884
I like it's position now, so I'm just living with it.
Previously:
08-01-2020, 12:30 PM | #14 |
Rep 15
Plate
I have the same Milworks front plate bracket and had problems with the sensors as well.
I found that tilting the plate at a slight angle to increase the distance from the front most parking sensor seemed to help reduce how often its picked up. But as others have said, its still a bit temperamental. |
08-20-2020, 01:53 AM | #15 | |
Rep 548
FYI - I didn't know it was an option until I ordered the phone mount. My good friend has the ECS installed w/o issue. Both are good options. |
09-27-2020, 08:54 PM | #18 |
Rep 304
I had a similar issue and was able to get it just right - I only had issues when it was raining. I ended up going with a Carbonio which I can remove in 30 seconds.
09-27-2020, 09:09 PM | #19 |
Rep 612
+1 for Carbonio. I've had it on my car for 3 years with no issues. Easy to put on and take off and it doesn't interfere with anything. I take it out when getting the car detailed. I even hit a tumbleweed and it held up (the license plate bent though)
2018 F80 M3 Comp, Silverstone Metallic II, w/ black 666M (Ordered: 7/9/2017 | Pickup 9/9/2017)
1998 E36 M3, Cosmos Schwarz Metallic 2009 E82 135i, Montego Blue |
CYANiDE167.00 |
