06-24-2016, 01:20 PM | #1 |
Rep 52
Got my Ohlin R/T
6/27 Added additional pics with some notes. First things first, big thanks again to Alex, Matt, Tommy, and everyone else at Autocouture. They did an amazing job on my car and I couldn't be happier. Would not hesitate to recommend them. Definitely worth the drive up from Virginia.
Please be aware, I am coming from passive suspension, so the ride (from what I am told) was already a little more firm than sport for those that have adaptive. That being said, I actually enjoyed the firmness and I live and daily drive this car in DC, where we do not have the best of roads. Install notes: For those that are looking for a dumped look or an aggressive drop, this is not the kit for you. I am almost at the lowest setting and the drop is pretty minimal, probably around 3/4" to 1". This is perfect for me, but if you want to be slammed look elsewhere. The rear, btw, is also approximately at a 1" drop. Also an important item to note, my kit was missing the front top nut. The install instructions said to re-use the stock nut, but it did not fit. Maybe since I had the first kit it was missing but went out to the hardware store and grabbed another nut so the install went on without incident. But for those of you that are getting the kit early I would check this. I attached a pic for reference. Driving Impressions: Well I've only put 300ish miles on the suspension so far, and I need an alignment, so please take what I say with a grain of salt. So far the suspension feels great! All the usual things people say. There is noticeably less body roll and the car feels very well damped, stock the car felt more ... floaty? definitely not now, the car feels very planted almost like its being pushed into the ground. When I've installed coilovers on other cars, the ride was typically a bit more busy/jittery I am not getting those impressions now. I will be honest, the ride is firmer, maybe 10% more than stock but I'll play with adjustments a bit (I am on Ohlins recommended settings - can't remember what they are right now but will find out). On bumpy roads the ride is a bit more harsh, again I'll play with the settings a bit, but on smooth roads the ride is amazing and more comfortable than stock, I couldn't be happier. That's all I can think of for now. I'll put more miles on the system and update my thoughts. 6/25 Updated with pics. Super tired from driving but I'll update tomorrow. In short car feels very planted. Steering has changed too ... Almost heavier. Very happy so far. I know there is skepticism on the Ohlin Kit actually being released and shipped so I thought I should let everyone know that I got mine today . I know, I know, its not true until you post a pic, but sadly, and even though I am an engineer, I do not know how to post pictures from my phone . I will however post some pics once I get home. Big thanks to Alex@AUTOcouture for making this happen. I'll be getting these put on this weekend and will report back. Last edited by mr_tofu; 06-27-2016 at 10:54 AM.. Reason: Updates |
06-24-2016, 02:25 PM | #2 |
Rep 1,338
Drives: Round n' Round
how are those 1300lb+ per inch rear springs treating you? or did they revise the spring rates from their publication
06-24-2016, 02:46 PM | #3 | |
Rep 1,755
They are indeed out. I have my scheduled install for these on July10th. I can't wait to get a proper suspension on this car, as BMW left WAAAY too much slop in the stock set-up.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
06-24-2016, 02:50 PM | #4 | |
Rep 1,755
Two things to consider... The relocation point of the springs requires a stiffer set-up The shocks have dual flow valves. Despite the spring rate, I'm betting they are smoother than KWV3 or Clubsports
18? Camaro 2SS 1LE
06-24-2016, 03:29 PM | #5 |
Been there and back...
110
Rep 142
Looking forward to feedback from you all on these!
06-24-2016, 06:05 PM | #7 |
Rep 5,515
What do you mean by "relocation point of the springs"? The Ohlins R&T rear setup is identical to the stock rear setup.
06-24-2016, 09:13 PM | #9 | |
Rep 1,755
Coilovers, the spring is over the shock, hence "coilover"
18? Camaro 2SS 1LE
06-24-2016, 11:33 PM | #11 | |
6579
Rep 5,304
You might be thinking of the Ohlins TTX kit. That one had the true coil-over-shock set up in the rear. Last edited by x.shell; 06-24-2016 at 11:42 PM.. |
06-24-2016, 11:35 PM | #12 |
6579
Rep 5,304
06-25-2016, 12:22 AM | #13 | ||
Rep 1,755
Maybe because of the solid mounting to the frame?? Why wouldn't you do a true coilover in the rear on this platform?
18? Camaro 2SS 1LE
06-25-2016, 03:42 AM | #14 | |
6579
Rep 5,304
- The term "coilover" in the aftermarket industry has come to mean a shock/spring replacement with a threaded adjustable spring perch. This is not just exclusive to the BMW aftermarket. Every automotive scene (even beyond) has adopted this meaning. While most OEM suspensions are "coil-over-shock" suspensions (yes, your neighbor's Volvo has coilovers), this is usually not what a person is referencing when they ask, "Did you get coilovers on your car?" What they really mean is, "Bro, did you get the thing that has the turning things that will lower the car bro?" Maybe because of the solid mounting to the frame?? - Ask BMW. They've been designing their rear suspension like this since whooly mammoths were getting stuck in tar pits. But they must be doing something right as they have some of the best handling road cars right out of the box. Why wouldn't you do a true coilover in the rear on this platform? - Because it's easier not to. Designing around OEM is always easier to fine tune and easier to sell. Although the true coilover design for the rear may increase lap times (I'll leave that to the track guys to figure out), it's simply not worth it for most people to try some thing so different from OEM. At the very least, there is the concern that the rear strut point may not be able to handle all of the stress without being reinforced (the concern is anecdotal but legitimate). So far the Ohlins TTX and Motion Control offers a true "coil-over-shock" set up for the rear. The point to all this was... why are the Ohlins R/T rear springs so stiff? |
06-25-2016, 06:54 AM | #15 |
Rep 5,515
Greg FEightytwo1312.50 |
06-25-2016, 07:00 AM | #16 | |
Rep 5,515
Also, if the rear is switched to a true coilover setup, the motion ratio increases and, therefore, the spring rate decreases, not increases. Front and rear spring rates will end up being very similar (e.g., F/R 500/450 lbf/in) for a rear coilover setup. |
06-25-2016, 10:01 PM | #20 | ||
Rep 52
06-25-2016, 10:13 PM | #21 |
Rep 1,338
Rear spring is not a true coilover, its same set up as OEM. If it was a true coilover due to the folcrum point you would reduce the spring rate not increase it to achieve the same effect. Anything over 800-850# per inch for the street as a daily is gonna be rough. OEM springs are around 500 in the rear and all other CS kits are around 800....The good news is that springs swaps are cheap
06-25-2016, 11:47 PM | #22 |
6579
Rep 5,304
Jeez those look pretty. I want to get a set to hang on my wall and just stare at it.
Travishksar41.50 |
