04-08-2021, 11:44 PM | #1 |
Rep 195
Please Help!Annoying noise from brake booster or pedal after brake fluid replacement.
Hello, everyone.
my F80 is 2018 which is required to change brake fluid this year. There is a super annoying noise from brake booster or pedal after brake fluid replacement. I'm not pretty sure if it is from booster or pedal. Probably from the booster. The shop who did the fluid changing work does not use the pressure power Bleeder. They just release the fluid from caliper and another guy was stepping on the brake pedal several times. I've tried to apply some lubricant or WD-40 silicone spray inside the booster , but it does not work. please help if anyone knows what the issue it is. Thank you so much and really appreciate. As the videos' link below. |
04-10-2021, 09:43 AM | #3 |
Rep 195
04-11-2021, 10:40 AM | #4 |
Rep 343
My issue was not the brake booster, but the actual master cylinder itself. That's the part that the metal rod connects into. You may want to have a shop diagnose it to see if it's the same issue, as it will cost about 1k to replace the master cylinder if you're paying for labor. The part is about 450.
ericson11254.00 |
09-29-2021, 10:38 AM | #5 |
Rep 16
Hello mate,
Do you have any news about your problem ? I have exactly the same problem on my M2, I also tried to put some lubricant but the squeak remains. Except that the brakes are working really well. Cheers |
10-02-2021, 12:06 AM | #6 |
Rep 195
10-03-2021, 05:00 AM | #7 | |
Rep 16
10-03-2021, 07:19 AM | #8 | ||
Rep 195
2. Before you do the this. , try to do the 1. you may solve problem. If not, replace a new master cylinder will make the noise gone. At least it works to me, I replace a new master cylinder with new brake fluid (low viscosity ). I'm wondering which brake fluid you used for you m2? The Ate(blue bottle ) I used will cause the noise. |
10-13-2021, 03:41 AM | #9 | |
Rep 16
Regarding your solution, did you went straight to replace the master cylinder or did you try to flush the brake fluid first ? Thanks for your help. Regards. |
10-16-2021, 06:32 AM | #10 | |
Rep 195
just replace a new master cylinder with new brake fluid . will fix the issue
01-19-2022, 09:46 PM | #11 | |
Rep 78
Thanks! |
01-19-2022, 11:53 PM | #12 | |
Rep 343
I ended up replacing the master cylinder and the squeak went away. However, when I flushed the brakes again with ATE a few months later, the squeak came back. I read this is a common issue on Porsches with ATE typ200 fluid. I flushed with bmw low viscocity fluid and the squeak stayed there until after 25 oz of fluid was flushed through. Then it magically went away and has been gone for months now. It's definitely the fluid causing the issue. I'm sticking to bmw fluid now and just flushing more often. |
01-20-2022, 07:38 AM | #13 | |
Rep 78
If not I'll try flushing the whole system again using the BMW fluid |
02-14-2022, 10:03 PM | #14 | ||
Rep 195
11-18-2022, 05:20 PM | #15 |
1289
Rep 1,955
Wanted to add to this since my F82 with OEM BMW Brake Fluid (Less than 2 years old) is now having a squeaky brake pedal upon release (not on application)
The issue in my case is the Brake Booster. I had no loss of braking power or anything like that. It just squeaks when releasing the brake pedal.
01-24-2023, 06:45 AM | #16 | |
Rep 625
01-24-2023, 11:52 AM | #17 | |
1289
Rep 1,955
01-25-2023, 06:14 PM | #18 |
Rep 625
Did they replace the master cylinder while everything was apart? Some people said their squeak went away with a replacement master cylinder.
01-25-2023, 10:22 PM | #19 |
1289
Rep 1,955
No, they replaced everything except the master cylinder. Don't know why they did that lol. It's going back again next week.
01-27-2023, 07:45 PM | #20 | |
1289
Rep 1,955
I'm like pulling on it and it's just not budging.
02-12-2023, 02:07 PM | #21 |
1289
Rep 1,955
For people who will come across this or from a google search, the noise for me also came from the Master Cylinder. I am on OEM BMW brake fluid this whole time so it's not anything to do with the viscosity of the brake fluid. On the work order, the tech also tried to lube the plunger prior to replacing the Master Cylinder and it did not change anything.
