      03-22-2019, 03:35 AM   #1
BTm42001
Drives: BMW M4 coupe
Help ! Offset and tire question for my M4
Hey All,
New to the scene here.
I wanted your help as I got some new wheels for my f82 m4.
20x9 et 25
20x10.5 et 26.
Will they fit on my m4? It is currently lowered on H&R SS and I also have spacers all around on my stocks to give it a flush look
The wheels are originally off a e92 m3. Will they fit on m4 f82? Also what tires do I need? 255/30 & 285/30?
Thanks,
      03-22-2019, 04:48 AM   #2
M3SQRD
M3SQRD's Avatar
Drives: E92 M3,R56 S,F22 240iX,F82 M4
The front is fine (may need a spacer depending on what look you prefer) but the rear is pretty aggressive. Typically, a rear 10.5Ē wheel has an offset between 33-35 mm.
      03-22-2019, 06:17 AM   #3
LOW4LYF
LOW4LYF's Avatar
747
Drives: ///M4 COMPETITION
I had a 11" et25 with 285/30 PSS, no issues
bevo190.00
      03-22-2019, 11:55 AM   #4
BTm42001
Awesome. Thanks guys. I saw some on here with similar setup. As long as I can get away with no rubbing ill be happy. Yes fronts will probably need spacers.
      03-22-2019, 12:19 PM   #5
M3SQRD
M3SQRD's Avatar
How much negative camber did/do you have to run? Iím currently running a 19x11et40 with 305/30 PS4S and I couldnít go anymore aggressive without rubbing. Iím running -1.8 deg of camber on the rear.
A 285 will be slightly stretched on an 11Ē wide wheel but youíre also running a 15 mm more aggressive offset. Volks with 11et34 can barely run a 285. Do you have pics of your rear setup?
      03-22-2019, 12:44 PM   #6
ntgarage44
ntgarage44's Avatar
Drives: '17 M3 Mineral White 6MT
I have 10.5 +30 in the rear on my M3 with Continental ECS 285 and Macht Schnell springs. one finger gap between entire tire sidewall and inner fender. Any lower or wider and I'd be riding the fender walls. Not sure if M4 has any more clearance, but H&R Super Sports are really pushing it.
      03-22-2019, 01:07 PM   #7
LOW4LYF
LOW4LYF's Avatar
747
20x11 et25 285/30 PSS no issues
View post on imgur.com
      03-22-2019, 01:19 PM   #8
LOW4LYF
LOW4LYF's Avatar
747
Stock camber
Currently running a 305/30 on a 20x12
      05-02-2019, 08:03 AM   #9
iewgnaw
I'm in your face
iewgnaw's Avatar
Stock camber
what is the ET on the 20x12? Thanks
Follow me on Instagram: M4rylandf82
exterior: Enlaes front lip, Mode Carbon r1 rear diffuser, M performance trunk lip, M performance mirror caps
performance:AWE non-resonated exhaust 90mm diamond black tips, Swift Springs
Wheels:Volk TE37SL Mag Blue 18x9.5/18x11
      07-11-2019, 08:50 PM   #10
JoshFND
Drives: M4 shopping
How much negative camber did/do you have to run? I'm currently running a 19x11et40 with 305/30 PS4S and I couldn't go anymore aggressive without rubbing. I'm running -1.8 deg of camber on the rear.
A 285 will be slightly stretched on an 11" wide wheel but you're also running a 15 mm more aggressive offset. Volks with 11et34 can barely run a 285. Do you have pics of your rear setup?
Stock camber
[IMG]
[/IMG]
Seems your good on your fitment numbers.
Currently grabbed a deal on a set.
20x9.5 + 15
20x10.5 + 15
Able to pull this off in the rear with stock camber adjustment and a 265/30/20??
Fronts I may go with a 245/30/20
Copyright ©2000 - 2019, vBulletin Solutions Inc.
