INDustry distribution
      07-17-2019, 09:38 PM   #1
domino_z
Australia
914
Drives: F80 CP
Best looking aftermarket 19" setup....
...and go
looking for convincing to ditch my oe 666's and embrace more sidewall
ccb fitment pics preferred
F80 ZCP #itsoktobeAWonSS - ceramics, mpe + fabspeed mid, oe GTS hood, tractive suspension, eventuri, ps4s.....and a sunroof
      07-17-2019, 10:20 PM   #2
minn19
minn19's Avatar
Drives: 19 M4 CS, 16 F150, 19 M550
666s are heavy and ugly IMO so that is the easy part.
Money no object my vote would be for BBS FI-Rs.
NickyC4722.00
      07-17-2019, 10:53 PM   #3
icegrill
icegrill's Avatar
174
Drives: 2015 M3
Can't go wrong with a set of Volk te37s
      07-17-2019, 11:12 PM   #4
Shadow2
Drives: '16 MG F80 M3
Signature SV701......although I love me some FI-Rs and Rays also. There's really an abundance of good wheel choices these days.
      07-18-2019, 12:24 AM   #5
domino_z
Australia
914
Drives: F80 CP
It's tough to find a 19" aftermarket wheel that looks good on this car without having to be slammed
      07-18-2019, 01:27 PM   #6
Shadow2
Mines hardly "slammed", just M Performance HAS spring kit, only a slight drop really, perfectly fine for daily driving duties. Just gotta be a little more cautious on steep driveways and such. But yes, the stock front gap has to go, on any wheel imho.
      07-18-2019, 02:24 PM   #7
Sd335i2007
Sd335i2007's Avatar
Drives: E90
19's with tire meat. However on coilovers.
FBO N54 stage2pure High-Flow Turbos w/RB inlets
Ceramic coated AR catless Dp's
Active Autowerke race FMIC
MangaFlow exhaust with X-pipe
Bilstein b14 PSS coilovers
JB4 G5 w/ BEF MHD
Fuel-it Stage 2 LPFP
Wolf Racing CP/ Tial Bov
Wolf Racing DCI
BMS meth kit
Trebila Custom e50 tune
In process of building n54 closed deck engine
JE piston: Molnar rods: CSS closed deck block
Stage 3 Ported/polished head with Ferrea valves
rhk118397.00
maniz543.50
Jockey1794.50
GERMAN M31448.50
      07-18-2019, 04:59 PM   #8
rhk118
Poop
rhk118's Avatar
Drives: F80 ZCP 6MT
19" BBS FI-R in Diamond Black. They are a bit dusted on there which is the discoloration in the second picture (need a new wheel cleaner that doesn't rust the rotor, because that rust likes to stick to the wheel), and dropped it a bit since that last pic.
Not dusted when they were clean:
2018 M3 / SSII / 6MT / 19" FI-R / MP-HAS / MPE
"Man who run in front of bus get tired, Man who run behind bus get exhausted"
Appreciate 5
domino_z914.00
maniz543.50
      07-18-2019, 05:14 PM   #9
TopJimmy
TopJimmy's Avatar
Drives: BMW M3 F80
I love BBS on BMW. I need to make up a set of BMW caps like the guy with FI-Rs. I ordered a set of red BBS caps but his custom jobs look so nice.
Full write-up on fitting these CI-R's:
https://f80.bimmerpost.com/forums/sh....php?t=1635230
-TopJimmy
rhk118397.00
      07-18-2019, 05:35 PM   #10
ApexRaceParts
We might be a bit biased here. If you're looking for a great 19" setup for street and track use we would recommend the following fitment:
Front: 19x10" ET25 with 275/30-19 tires
Rear: 19x11" ET44 with 305/30-19 tires
  • Brake clearance: SB CCB
  • Available in SM-10 design only.
  • 5mm front spacers may be required for certain aftermarket suspensions
  • Front 19x9.5" ET22 wheel can be used to avoid running spacers with certain aftermarket suspensions due to its superior inner clearance.
  • 315/25-19 rear tires may also be used, but may require rolled rear fenders and/or negative camber.
  • Rear 295/30-19 tires can also be used.
Alternatively, we have another staggered fitment that is much closer to the OEM fitment, listed below:
Front: 19x9.5" ET22 with 255/35-19 tires
Rear: 19x10" ET25 with 275/35-19 tires
  • Brake clearance: SB & CCB
  • Available in ARC-8, EC-7, and SM-10 designs only.
  • Direct fit.
  • 265/35-19 front tires may also be used.
If you have any other questions, feel free to shoot us a PM! We've got more than a few great 19" options for the F8x M3 and M4 chassis, stock or modified!
- Max
domino_z914.00
      07-18-2019, 07:09 PM   #11
aBMWfan
Drives: '15 M4/ '09 M3/ '04 M3/ '95 M3
  • Direct fit.
- Max
Hi, when are you offering Forged wheels?
      07-18-2019, 07:44 PM   #12
Wmf80
Drives: f80
Never....
      07-18-2019, 08:35 PM   #13
FatRear08
FatRear08's Avatar
460
Drives: 2015 F80 M3
Signature SV104ís. Reasonable price, light, strong, and easy to look at.
Appreciate 8
      07-19-2019, 09:48 AM   #14
FreeDarko
Drives: F80
All the pics in this thread with 19s proves Domino's point. The car needs to be lowered to make it work aesthetically.
Nevertheless OP, having larger sidewalls makes a significant difference in day to day driving with OEM setup, even with EDC.
domino_z914.00
      07-19-2019, 10:44 AM   #15
domino_z
Australia
914
Drives: F80 CP
I have a subtle drop on my tractive edc suspension
This is at min drop, I could go lower but taking travel out of the shock will start to defeat purpose of seeking a more comfortable ride
The tractive shocks have sorted the dampening, but what I still get is the harshness from potholes, road reflectors, train tracks, coarse bitumen etc from that 30 series sidewall
I'm picking up a set of loaner oe 19s this weekend to test out
      07-19-2019, 03:01 PM   #16
pikkagtr
Go Spurs Go
pikkagtr's Avatar
Drives: 2018 AW F80
OEM 763M in 19s staggered
Buy the M2C fitment
OE quality, looks like the BBS and much cheaper for forged wheels
      07-21-2019, 08:39 AM   #17
MWM
Drives: 335i (E90)
FI-R
My car is disgusting, sorry -- washing it today. Damn cosmoline keeps dripping from the doors and staining the skirts. Need drop in front too.
But: FI-Rs are just f'n bananas on these F80s. 19s in satin black here.
Shadow234.00
rhk118397.00
      07-21-2019, 05:30 PM   #18
Justin.AutoTalent
Justin.AutoTalent's Avatar
2657
Here are a few pics of different set ups I've had
domino_z914.00
yjypm128.50
GERMAN M31448.50
      07-21-2019, 06:27 PM   #19
domino_z
Australia
914
Drives: F80 CP
Yep I've decided to go rc100
Did you ever run a 19x10/11 setup
Do I just let HRE work out the offsets?
I want to replicate this fitment on the laptime performance car
      07-21-2019, 10:13 PM   #20
yayaya
Drives: BMW 335xi E92 N55
Like'em dirty.. making me think about putting summers on my Apex wheels.
      07-21-2019, 11:28 PM   #21
Justin.AutoTalent
2657
This matching set of classics we ordered for a friend/customer of mine were 19x10/11
I dialed in the fitment for him
265/30/19 | 295/30/19
No rubbing
      07-22-2019, 02:22 AM   #22
hellokitty
hello kitty oke ??
hellokitty's Avatar
North Korea
692
Drives: '17 M3 ZCP DCT | '12 335iS DCT
2012 BMW 335iS  [0.00]
2017 BMW M3  [0.00]
Buy the M2C fitment
Whatís the difference between m2c vs f80/f82 fitment?
Copyright ©2000 - 2019, vBulletin Solutions Inc.
