08-06-2020, 01:25 PM | #1 |
Rep 8
M4 won't start after ECU tuning attempt
Hello folks! First of all, English is not my first language and I'm new to the tuning scene so please excuse any mistakes.
A couple of weeks ago I bought a Wagner Downpipe with sport cats and an Injen intake for my 2019 M4 Competition, since it has a OPF filter and I wanted to get a better sound. When I bought the parts I was proposed to also make a Stage 2 tune so I accepted. After installing the new parts, they tried to use Kess v2 to do the tuning, but apparently the car wasn't detecting the car key fob and after 4 attempts the car got locked and now it won't start or turn on. Is there a reason why the car won't start/turn on? Is there a way to get it unlocked? They are trying to retouch the ECU with AutoTuner but for now they haven't fixed it. Thank you Last edited by pipiolo; 08-06-2020 at 01:35 PM.. |
08-06-2020, 06:07 PM | #3 | |
Rep 8
Thank you for your reply! |
08-06-2020, 06:55 PM | #4 |
/M Enthusiast
1599
Rep 1,618
For others, I always leave my key fob by the shift lever when flashing my cars.
I usually stand outside the car, laptop on the roof and cable through the open window. First thing I do. It’s too easy to get distracted and walk away.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
08-06-2020, 07:14 PM | #5 | |
Rep 4,106
I would keep the trunk open just to be able to disconnect the battery for a reset if needed. |
pipiolo0.00 |
08-06-2020, 07:17 PM | #7 |
/M Enthusiast
1599
Rep 1,618
I have to disagree, I’ve had a flash stop because the car no longer saw the key.
Better safe than Fckd.
pipiolo0.00 |
08-06-2020, 07:20 PM | #8 | |
Rep 4,106
The car is in flash mode and not looking for any key anyway. There is no CAN communication during flashing so no ECU would request the Key. Usally the car turns off because of weak battery. Last edited by LOW4LYF; 08-06-2020 at 07:27 PM.. |
08-07-2020, 01:19 AM | #9 |
Rep 8
That's exactly what happened to mine, it was showing an error saying that the key wasn't being detected and after 4 attempts it got blocked. Now they're still trying to unlock it.
08-07-2020, 03:13 AM | #10 | |
Rep 4,106
Guys, if you flash any ECU all ECU's and the whole car goes into a flash mode. No ECU requesting the key because there is no communication on the CAN during flashing. Put a battery charger on, and the seatbelt so the ignition won't go off. Is your car currently locked or unlocked? If your car is locked, use the hard key to open the door manual. Open the trunk, disconnect the battery for couple minutes and flash the ECU one more time! You don't need ignition on for flashing as long as the CAN is on. Btw. OP... Where are you located? Last edited by LOW4LYF; 08-07-2020 at 03:23 AM.. |
08-07-2020, 04:46 AM | #11 | |
Rep 8
08-07-2020, 08:41 AM | #12 | |
Rep 8
- CF1801 - CF1701 - CF1601 - D35586 - D3542F - 138104 |
08-07-2020, 10:18 AM | #13 |
Rep 4,106
Does it crank at all when you try to start it?
08-08-2020, 02:51 AM | #14 |
Rep 8
I haven't asked that and I haven't touched the car since I left it there.
I have an update though, they took the car to the BMW dealer and they will be putting the original maps on it. The BMW technicians told them that the issue was caused by the DME lock and the anti tuning measures, so they will revert everything back to the original settings. I think that I will do the DME unlock somewhere else and then I will just get a custom bm3 tune rather than having to deal with these guys again. Thanks again for trying to help me! |
