R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      05-09-2019, 07:40 PM   #1
trey100
trey100's Avatar
Drives: 2020 M2 Competition
Hi everyone.
I noticed this on my N55 335 as well so not sure if this is normal. I'm just noticing it now on my S55 F80 but it could very well have always been there.
It happens between 3rd gear and higher (mostly because rpm increase is slower) under load. So for instance say going up a hill in 3rd gear, Rpm currently at 2,200 rpm. Roll into the throttle and as the rpm passes 2,500 rpm, what sounds like a sheet of paper flapping in the wind sound comes in and lasts for about 500-750 rpm (may be longer but that's when you really notice it). Sound can also be similar to someone blowing into a spinning fan.
I've been doing some googling and can't see much except perhaps some folks experiencing this on other turbo models and pin pointing it to the diverter valve springs? Basically cracking open when it should be closed and leaking some boost?
Anyone come across this?
      05-10-2019, 09:28 PM   #2
BlatantMaple854
Drives: 2017 f80 M3 ZCP DCT
Is this the sound you are hearing?
https://www.youtube.com/watch?v=EgU_yV3PYEE
      05-11-2019, 03:10 PM   #3
trey100
trey100's Avatar
Nice find. Tough to tell but it is similar. Didn't see a diagnosis though. Went to BMW and of course it wasn't doing it. Not today. Googling I found people talking about something similar and they said perhaps the diverter valve gets stuck sometimes and let's some boost leak by. But like I said they didn't do anything. Car driving normal now.
I definitely noticed the same sound on my N55 335 when I had it. Not all the time in that case either.
      05-11-2019, 05:01 PM   #4
tebbnsx
2018 BMW M3  [0.00]
My car makes a noise like that when the AC is on and I’m accelerating. When it’s turned off there is nothing.
      05-11-2019, 06:13 PM   #5
BlatantMaple854
Yup, that’s my original video. Tell your dealer that they need to add an additional weight to the low pressure line for the HVAC. Apparently it can rattle in a certain rpm range somewhere from the engine bay through the firewall.
      05-11-2019, 06:14 PM   #6
BlatantMaple854
Run a test to see if the noise is only present when the AC is on. If so, take a look at my post above for the solution.
trey1001125.00
      05-12-2019, 07:23 AM   #7
trey100
trey100's Avatar
Thanks! I'll try it out.
      09-09-2020, 07:03 AM   #8
KeyBoy
Did you ever get this resolved? Having same issue. Trying to get dealer to fix it but couldn't replicate the sound.
      09-09-2020, 08:44 AM   #9
White340
Drives: 2018 M3 Comp / 2022 X5 45e
Glad this was bumped. I also have the same sound. There is a weight that you put on the low pressure AC line that is supposed to fix this. It only happens with the AC on and under load. Makes the car sound like it's breaking down while accelerating.
I want to diy this as I don't want the dealer taking my car out for a joyride and it's a cheap part but I don't know where exactly the weight goes.
Can someone take a pic of the weight that the dealer added?
Thanks
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO
2016 340i xDrive : AW/CR (sold)
      09-09-2020, 09:24 AM   #10
KeyBoy
Thanks
Yeah, it would be helpful to know how to access the low pressure AC line and where to actually clamp the weight on the hose.
Are you tuned? I notice the sound is more prevalent with a tune and more intermittent on stock tune.
      09-09-2020, 09:29 AM   #11
White340
Thanks
Nope, fully stock
      09-09-2020, 09:32 AM   #12
KeyBoy
Seems like F30 platform had same issue. Here's a pic of the second weight added (though not S55).
      09-09-2020, 10:00 AM   #13
White340
Thanks, s55 looks different. Can't find that hose. There was a TSB for this which I guess also has instructions if someone has access.
      09-09-2020, 10:47 AM   #14
KeyBoy
Found this thread that I think shows where it is.
https://f80.bimmerpost.com/forums/sh....php?t=1381897
Both dealers I went to said there was no TSB for this issue which is unfortunate. For F30, there is.
      09-11-2020, 08:34 PM   #15
trey100
trey100's Avatar
It went away on its own. I had this same issue on my N55. It seems like something gets stuck and then just resets itself at some point.
      09-23-2021, 07:43 AM   #16
agustincuenca
Drives: 2008 E90 335i; 2016 F80 M3
2016 BMW M3  [0.00]
2008 BMW 335i  [0.00]
Thank god I found this thread. I have this exact same issue/flutter on my 2016 F80 M3 and as said before only happens when the AC is on and exactly between 2500 to 3000 RPMs. Did anyone found a DIY way to mitigate it or fix it?
If not, then I'll probably mention it when I bring the car in for the next oil change at the dealership.
      09-27-2021, 07:52 PM   #17
trey100
trey100's Avatar
Mine seemed to go away on its own. Strange.
      05-25-2022, 11:41 AM   #18
Blazinskunk
Drives: 2018 M3
Just started hearing this on my 2018 M3. Does anyone know if the weight/clamp on the hose will resolve this?
      06-08-2022, 08:50 AM   #19
agustincuenca
2016 BMW M3  [0.00]
I'm planning on doing spark plugs soon and I will look into the AC hoses mentioned here while I have everything apart and will update here.
      06-14-2022, 06:44 PM   #20
DrewDDS
Drives: f80 m3
https://www.ecstuning.com/b-genuine-...t/64539322952/
Here's the part. You have to take off your intercooler, then you can access the a/c line
      06-14-2022, 08:34 PM   #21
agustincuenca
2016 BMW M3  [0.00]
MVP, Thanks!
      06-14-2022, 09:14 PM   #22
White340
Do you have a picture of exactly where it goes on this car? All I can find is a pic on the N55..
