ARMA SPEED
      07-16-2018, 12:44 AM   #1
MisterF80M3
MisterF80M3's Avatar
1047
Drives: 2018 M3
Exclamation Where to buy this plug for the exhaust?
I am trying to unplug the plugs for the exhaust to keep the exhaust valve permanently open.
I am looking for the male plugs and female plugs pictured below. Anyone know where I can buy these?
2018 BMW F80 ///M3
570WHP/578TQ
      07-16-2018, 02:52 PM   #2
IK6SPEED
Drives: BMW M3 / AH3
      07-28-2018, 03:30 PM   #3
MisterF80M3
1047
Drives: 2018 M3
Originally Posted by IK6SPEED View Post
Thanks.
I tried looking for the part number you listed but not having any luck.
2018 BMW F80 ///M3
570WHP/578TQ
MSR100.00
      07-28-2018, 05:48 PM   #4
Luc@Speed&Tech
Luc@Speed&Tech's Avatar
1267
Drives: G80 M3, E92 M3, F56 JCW
Bmw Pn: 18302411427
Speed & Tech Motoring
23585 Overland Drive, Unit 178
Sterling, VA 20166 (Headquarters)
23541 Pebble Run Place, Unit 140
Sterling, VA 20166 (Satellite shop)
      07-29-2018, 08:22 AM   #5
2kaccordocoupe
2kaccordocoupe's Avatar
Drives: Former ///M Driver
Why not use electrical tape, hear shrink tubing etc...
      10-17-2018, 10:13 PM   #6
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
OP, did you find a supplier for the female connector? I purchased the dummy plug for other end, but I would like to close off the connector using a female connector. I think this is better than electrical tape, which is likely to fall off.
I have been able to confirm the connector is made by Hirschman but I haven't found a part number.
      10-18-2018, 09:47 PM   #7
MisterF80M3
1047
Drives: 2018 M3
I ended up using electrical tape on the male and female connector. 3000 miles later and still holding up fine.
2018 BMW F80 ///M3
570WHP/578TQ
      01-23-2019, 08:44 AM   #8
mzakariyya
Drives: BMW 435i
reply to get dummy plug
May i ask where you got the dummy plug from?
      01-23-2019, 11:37 AM   #9
f80er
Drives: An M3
You can get them from alibaba, I got a 5 pack for like 6 bucks from china.
Look for this part number: 7549032-02
https://www.aliexpress.com/wholesale...ext=7549032-02
      11-17-2019, 02:10 AM   #10
623baller
Drives: 2015 F80
your link doesnt work anymore, this one is the same?
https://www.aliexpress.com/item/32841771109.html
how did you plug the holes on the female connector?(circled in red)
      11-01-2021, 02:12 PM   #11
AbnormallyAspirated
AbnormallyAspirated's Avatar
Drives: 2016 M235i 6-Speed Convertible
I need the female part for the exhaust flap harness - Source?
Hi:
My new-to-me had the flap connector unhooked, and it corroded. I's like to replace it. Anyone know a good current source or part number for the connector and pins that go on the wire, and which plugs into the exhaust flap actuator?
      08-07-2023, 11:22 PM   #12
davidcher17
Drives: 2019 X5 XDrive40i
Did you ever order this? Wondering if it’ll fit on the X5 G05 also?
      08-15-2023, 07:00 PM   #13
623baller
Drives: 2015 F80
yep went with it and worked on f80, cant comment on x5
