03-22-2019, 07:49 PM | #1 |
74
Rep 296
BimmerCode: “A/C Setting Memory” won’t code correctly
Drives me crazy that the A/C - Heat HVAC comes on every time you turn the car on. So I was looking forward to coding this off so it wouldn’t turn on when starting up the car every time.
This is the only item that didn’t code correctly using the BinmerCode app. Anyone else have this issue or know how to resolve this? I contacted BimmerCode support but haven’t heard back. Thank you!
2022 G82 ///M4 6MT 2016 I12 i8 COUPE (SOLD) | 2019 F82 ///M4 6MT (SOLD) | 2001 E46 ///M3 CV 6MT 2015 F82 ///M4 6MT (SOLD) | 2000 E39 540i SPORT 6MT | 2012 E92 ///M3 6MT (SOLD) |
03-22-2019, 07:52 PM | #2 | |
Rep 18,821
03-22-2019, 08:20 PM | #3 | ||
74
Rep 296
For good measure, let the car sit idling with the A/C running for another 2 minutes. Proceeded to turn off the HVAC so nothing was blowing. Turned off ignition, exited car and locked it and went inside. Came back in a couple of hours to start the car and the HVAC turned right on with the car at start up. Did I miss a step?
03-23-2019, 07:20 AM | #4 | |
Rep 134
On IHKA Module: 1. memory_off set to be Aktiv And additional 2. Memory_unluft set to be Aktiv if you want the system to remember the circulation setting T
Instagram: @tafikhulafaa & @88tuning.id
03-23-2019, 10:30 AM | #5 | ||
74
Rep 296
03-23-2019, 08:32 PM | #6 |
74
Rep 296
Tried again to code it and it seems to work temporarily. As in right after I code and calibrate, I turn of HVAC and shut car off. Turn car back on and the HVAC doesn't turn on.
HOWEVER, when I exit and lock the car and let it go to sleep mode for 15+ minutes (or an hour or a few hours, whatever) and go back to the car, hvac turns back on. What the hell is going on?
03-25-2019, 09:49 PM | #7 |
74
Rep 296
Bump
03-29-2019, 10:27 AM | #8 |
Rep 134
try to access and the IHKA module using your bimmercode expert mode and set the MEMORY_OFF parameter to Aktiv like i said above.
please note that AC needs to remain on after coding under 1500RPM to complete initialization, wait until the light turned off. This typically takes about ~1min, but can be slightly longer. T
11-09-2019, 06:56 PM | #9 |
Rep 45
Did you try the solution given and did it work? I'm having the same issue.
2015 F80 MG/Blk MDCT
Stage 1, M Perf. Elect. Steering Wheel, GTS Coding, KW Clubsports, Other goodies. |
07-10-2023, 01:24 AM | #10 | |
Rep 99
