10-24-2019, 01:32 PM | #1 |
Rep 2,019
first gear won't engage?
i had this on my f30, and after ~7k miles it's now happening on my f80. regardless of engine temp, i'm sometimes (30-50% of the time?) unable to engage first gear on the first attempt. It gets half-way there, and feels like it's hitting something. The only way to get it to engage when this happens is to pop it back into neutral, release the clutch and try again.
Any ideas? Just bmw transmission idiosyncrasy, or actual issue?
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
10-24-2019, 01:44 PM | #2 | |
Rep 173
kolosy1486.50 nbennettksu1397.00 |
10-24-2019, 02:08 PM | #3 |
Rep 3,690
I know I'm not much help but I occasionally, though not too often have my DCT fail to engage a lower gear on kick down... so I wouldn't be surprised if this is normal as wsccsw13 stated.
The Ultimate Driving Machine. |
10-24-2019, 10:13 PM | #4 |
Rep 20,741
Engine temps have no incidence on the transmission.
What you describe can happen on any manual transmission when the car is not moving. It's a question of the first gear dog splines not being able to align. Releasing the clutch, or sometimes just moving the shifter in and out of another gear is enough to move the dogs so they can align in first gear.
10-24-2019, 10:28 PM | #5 | |
Rep 2,019
10-24-2019, 10:30 PM | #6 |
Rep 20,741
Synchros starting to wear down...
10-25-2019, 09:52 AM | #7 |
Rep 5,056
Do you routinely engage first when the car is still moving? I find it can be difficult/notchy when doing so. I always to try to come to a complete stop and double clutch into 1st.
10-26-2019, 11:04 AM | #8 |
Rep 2,019
no, not really.
10-26-2019, 11:05 AM | #9 |
Rep 2,019
seems a little early for that, no?
11-04-2019, 08:52 PM | #10 |
Rep 66
I'm having this same issue that just started this week! Not all the time but enough where it concerns me. I have 59k on my 15 F82 and haven't had any issues until now. If it is the synchro, is this something that can be fixed with a new clutch? Any idea if there is a possibility to fix issue without a new clutch? Cost of so?? Love this fucking car but any hiccup and I tend to freak so maybe I'm just being over zealous.
11-25-2019, 03:59 PM | #12 |
Rep 2,019
What was the issue?
11-25-2019, 06:16 PM | #14 |
Rep 486
11-26-2019, 03:21 PM | #16 |
Rep 6,863
Had this happen to me last night on my way home from work. Shortly after I got in the car I was stopped at a red light. When it turned green I went to go put it in 1st and it would not go in. After a few times of returning it to neutral and attempting to put it in gear it finally went in. I have had this happen a handful of times throughout my 3 years of ownership but dont find it to be a big deal nor anything unusual for a manual transmission.
03-28-2021, 02:08 PM | #17 | |
Rep 28
FWIW, I had service look at this many times but they can't reproduce it since it happens rarely. However, they told me I was the first person ever to complain about this at this dealer and they don't expect the F8x manual to have this issue. Go figure. |
03-28-2021, 11:55 PM | #18 |
Rep 988
I've never experience this before... From a stop, first gear is always able to go in.
I've had some issues trying to go into first gear when i had to slow down but then the cars in front start to move. Im talking creeping like 5-8 mph, you kinda need to add some gas when going into 1st gear for it to go in smoothly. What i should really be doing is go into second gear whenever the car is moving even if it is slow and will bog a little... |
04-05-2021, 03:21 PM | #19 |
Rep 15
I'd like to provide some data point here, I have exactly same symptom described by the op here on my 17 M4 6-sp , the only difference is I have it about 10%-20% of the time and shifting to 2nd then back to 1st always worked for me. I'm still under warranty so I sent the car to the dealer for diagnosis and BMW is recommending transmission replacement under warranty with no question asked. I believe the dealer did send a fluid analysis to BMW.
04-24-2021, 10:08 PM | #20 | |
Rep 28
05-19-2021, 02:07 AM | #21 | ||
Rep 15
Current: 2017 Blue F82 M4 ZCP 6-Speed
Upcoming: 2024 Skyscraper Gray G07 X7 40i MSport Previous: 2016 White F15 X5 |
05-28-2021, 07:07 PM | #22 |
Rep 31
I have this issue as well, probably 10-15% of the time. Extremely annoying. I've been driving manual BMW M cars for decades and never experienced this before, so there's no way it's normal. Changing trans fluid did not help. I fear sourcing a different transmission, and hoping it doesn't have the same issue, will be the only fix. Thanks - again - BMW! (just replaced my valve cover and intercooler because of stupid failures that should not happen on a car like this!)
2016 F80 M3 • Individual (1 of 1 in the US) Venetian Violet Pearl Effect • Silverstone Interior • 6sp. Manual • Carbon Roof • 666 Wheels
