11-04-2019, 03:26 PM | #1 |
Team Zissou
3065
Rep 10,197
DIY: Swapping in new head unit + touch screen
Recently the Spotify interface in iDrive stopped working for me (did it stop working for any of you too?). I think Spotify just stopped caring and did an update which killed support. Whatever the reason, I was pissed so I decided to upgrade to the newer head unit with wireless CarPlay so I could get my Spotify controls back (and all the other things I'd want like Waze in the iDrive screen).
I contacted steve@codemybimmer and ordered this plug n' play kit: https://www.codemybimmer.ca/product/...v=7516fd43adaa I also opted to upgrade my screen to the touch-enabled version. The install was very straight forward. Here's a brief overview of what you have to do. Tools needed: - 10mm socket for battery - T20 Torx screwdriver - Trim pry tool (not necessary, but nice to have) Step 1: Unplug the battery using your 10mm socket Step 2: Pull off the upper trim and unplug the lock and vent wires. Step 3: Pull off the lower trim. It helps to use a trim pry tool, but you can probably do it with your fingers Once that is done, this is what you'll see: Step 4: Unscrew the 4 T20 screws i have circled in the photo above. The faceplate will come off and there are 2 wires to unplug. In the photo below you'll see I decided not to unplug one of them and just left the faceplate connected. Step 5: Unscrew the 2 T20 screws circled in the photo above and slide out the head unit. Step 6: Unscrew the 2 T20 screws holding the screen down - circled above. Pull the screen up, then unplug the wire from the back of the screen. Step 7: Unplug all the wires from the old headunit and remove it. Step 8: Plug all the wires back in to the new head unit. Plug the W-LAN Antenna into the W-LAN port in the head unit. And reinstall everything as it was before. Beep bop boop done! The head unit comes coded to your car and works right out of the box. I added my phone and wireless CarPlay was up and running: If you have any questions about the install let me know! steve@codemybimmer was a pleasure to deal with. I recommend anyone looking to upgrade their system to shoot him a message! Last edited by jpsimon; 11-06-2019 at 07:56 AM.. |
12-07-2019, 11:50 PM | #4 |
Luxury at the redline :)
9105
Rep 7,563
For the record, It's possible Spotify isn't working because your ConnectDrive service is no longer active.
Recently, my Napster APP interface stopped loading also and I realize the reason was due to the fact it was tied to an expired plan. Upon renewal, it was back up again running within minutes. That's smart that you decided to retrofit ID6, since you can use Google Maps and bypass paying for Connectdrive online. I'm planning to do the same before my plan is up. Thanks for the writeup. Another DYI: |
12-08-2019, 01:45 PM | #5 | |
I /// M FAN
424
Rep 427
12-08-2019, 02:03 PM | #6 |
Rep 254
the link shows a 2016 bmw, would the retrofit also work for a 2015?
also same question about the connecteddrive stuff still working. i can tell what we get new but i'm curious about what we'd lose if anything.
- End of Line
12-16-2019, 12:00 AM | #7 |
Rep 400
12-16-2019, 12:09 PM | #9 | ||
Rep 10,473
For telecom boxes, NBT uses a TCB and NBT EVO uses an ATM. The wiring harnesses between the NBT and NBT EVO to Telecom box are also VERY different as well. The NBT Evo to NBT Evo plug and play described in Post 1 is a simple swap as it's simply replacing an NBT EVO HeadUnit with 8 screws. It's really not more difficult than changing the dashboard trim piece which literally anyone can do. An NBT EVO HeadUnit can be retrofitted and CODED in a NBT vehicle but it is more complex and you lose Connect Drive Services. If you want to keep Connected Drive with a NBT to NBT EVO retrofit, the retrofit is even more complex and costs grow by roughly $1000. It involves coding, a new wiring harness from the dash to the rear of the car and an ATM. A F30 member member recently did this complex retrofit. And a used, working and unregistered donor ATM is a needle in a haystack (though one is listed in the Classifieds currently). |
12-19-2019, 09:10 AM | #10 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Just an FYI, we're experimenting with modifying the logic boards on US NBT EVO head units to include a GPS port for those of you who have a 2015 model without the ATM telematics unit.
Once we have this available, it will work on the 2015 F8x vehicles along with pretty much any F chassis vehicle that runs on KCAN2. You will still not be able to use ConnectedDrive but everything else including Sirius XM will work. Stay tuned!
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
DjVb0.00 |
01-08-2020, 11:56 AM | #11 |
Some random guy
292
Rep 312
Finally had time to do the swap
Thanks for posting this!
The steps made it look relatively simple and straight forward, so I ordered the new HU and touch screen several weeks back. Just recently had time to make the swap and have loved the up-to-date look and CarPlay functionality. Many thanks to steve@codemybimmer for making the purchase super easy and being quick to reply to all my questions prior to and after making the decision to buy the retrofit components. I especially appreciate pointing me toward the coding option that reverts the controller setup to the pre-ID6 configuration. The change was easily performed using BimmerCode. (HU_NBT_Evo > ZBE_HARDKEY_LAYOUT_NEW > set to "nicht_aktiv") Bonus win: One thing that has always bothered me was the intuitively reversed nature of zooming the map (my brain wants a clockwise turn to zoom in - righty tighty, after all). While searching the HU ECU through BimmerCode, I found an option that was something like ZOOM_IN_DIRECTION_ZBE with options of "left" and "right." Default was "left," so changed it to "right" and it worked. The OCD traits are now slightly reduced while driving.
steve@codemybimmer664.50 |
01-10-2020, 02:58 PM | #12 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
01-10-2020, 03:56 PM | #13 | |
Some random guy
292
Rep 312
Of course, now I have to relearn the set up because I keep zooming out when I want to zoom in.
01-10-2020, 05:13 PM | #14 | |
Some random guy
292
Rep 312
Default value is left, so swap it to right and apply coding.
06-21-2023, 08:09 PM | #15 | |
Rep 416
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
06-22-2023, 02:03 AM | #16 | |
Rep 3,055
its plug and plug, no need for any mod
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
tgb1974142.00 |
