11-24-2019, 07:43 PM | #1 |
Rep 4,106
Section vs tread width?
I need a new 295/30 Michelin tire.
Can someone explain how the tread width can be different if section width is the same? Would any of both tires look more stretched? Thanks https://cdn1.imggmi.com/uploads/2019...231a1-full.png
11-24-2019, 07:49 PM | #2 |
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
11-24-2019, 07:51 PM | #3 | |
Rep 4,106
11-24-2019, 08:04 PM | #4 |
Rep 1,247
I don't think the section width change too much from same width tire but thread width can be very different. From my own experience, 325/25/20 pss and ps4s the thread width are different ( I recall it's 13.1 vs 12.2) I had pss then I switch to ps4s. It does clear just a little bit more. You can say it is more stretch if thread is more narrow.
11-24-2019, 08:31 PM | #5 | |
Rep 20,741
Now what is really confusing is that section width varies significantly depending on the wheel width the tire is installed on. The nominal section width of the tire's nomenclature is only valid if the tire is installed on the nominal wheel width it was designed for. On the other hand, the tread width remains essentially invariable to wheel width. This is what causes a tire to either look stretched or balooned depending on what wheel width it is installed on.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 11-24-2019 at 08:39 PM.. |
guess2098516.00 |
11-24-2019, 08:40 PM | #6 |
Rep 4,106
I'm running currently 305/30 and would like to try a 295/30 but the BMW 295/30 tread witdh is wider as on my current 305/30 which is a no go, 11.6 vs. 11.4.
