11-27-2019, 11:52 PM | #3 | |
Rep 170
I don't know enough about these engines to know if it's worth it. I personally haven't seen anyone worry about heat enough to do it. |
11-28-2019, 01:13 AM | #4 |
867-5309
76
Rep 308
Drives: F80 M3 ZCP and E36 328i
11-28-2019, 01:21 AM | #5 |
Rep 1,531
Ceramic coating mostly helps combat underhood temps. Is it worth it? I think so, just make sure you've done all the other basic mods first.
11-28-2019, 03:32 AM | #6 |
Rep 107
11-28-2019, 03:38 AM | #7 |
Rep 107
11-28-2019, 08:19 AM | #9 |
Rep 3,783
For the people confused - it's a different type of ceramic coating, it's for heat resistance.
nbennettksu1397.00 |
11-28-2019, 09:32 AM | #10 |
867-5309
76
Rep 308
11-28-2019, 10:11 AM | #11 |
Rep 1,335
Back in my big turbo Audi A4 days guys were seeing huge underhood temp decreases with ceramic coating on downpipes and turbos.
I say go for it and have your downpipes coated as well. |
Chris@VargasTurboTech1929.50 mdma-zn51.50 |
11-28-2019, 10:33 AM | #12 |
Rep 267
If it’s an option when ordering, go for it. It will help with temps and also exhaust flow.
Chris@VargasTurboTech1929.50 |
11-30-2019, 05:45 PM | #13 | |
ECUTek Master Tuner
10438
Rep 1,728
Drives: F80 M3 YMB
Most of the ceramic coatings on the market only prevent corrosion and do little to insulate exhaust temps. I coated mine, but only because I wrapped them with TI wrap and I dont want corrosion to build up over time
11-30-2019, 11:44 PM | #14 |
Rep 3,643
I've tracked my car in 100F weather giving it 100% all day.
F8X cooling systems are incredible (except for brakes --- mainly because there is no cooling). I never even open my hood to let the car cool off. The temps are always in the same range on Sport +/Sport whether I'm highway driving or running time attack in July. I can't imagine this would be worth doing in anyway but maybe I'm missing something. |
12-02-2019, 12:44 AM | #15 |
Rep 1,336
If I was putting in new turbos I would get the hot side and headers done. From personal experience this helped significantly with heat management on other cars that were converted from NA to boosted.
In saying this though if you are keeping stock frame turbo sizing and not changing the layout the car is already designed to sustain the heat so may not have a dramatic impact etc some will say it spools faster but cannot comment on this.
12-03-2019, 01:20 AM | #16 |
Rep 107
I ordered the turbo's with ceramic coating.
I have open BMS cone filters and my concern was ensuring IAT's stay as low as possible. Interestingly, my mate ordered without ceramic coating. Perhaps we could run the same OTS BM3 map and run some logs under the same ambient conditions... |
12-03-2019, 11:52 AM | #17 | |
Rep 53
03-17-2020, 10:51 PM | #18 | |
Rep 106
Kennethavery.com // Portland Real Estate
Wagner Evo 1 IC // Active Autowerke CP // JB4 + BEF // CAtuned Coilovers // AR Design D/P // Future Classic Spacers // E46 OE CSL Wheels // (PURE Stage 2 w/ wedge next!) |
03-18-2020, 08:12 AM | #19 |
Rep 107
Did not install turbo's yet.... I needed my car to go in to BMW for its 1st service which was wrapped up 2 weeks ago.
Since then Crank hub upgrade was completed along with some cooling mods. Working on fueling at the moment and then turbo's will go in. |
03-18-2020, 11:04 AM | #20 | |
Rep 3,152
Did you do port injection?
03-19-2020, 02:08 AM | #21 |
Rep 107
Stock internals - Going to keep power below 700 hp and torque will also be capped.
Fueling - Starting off with charge pipe/J pipe meth injection controlled with Torqbyte. "Hope you built the bottom end" sounds like you have experience to share? |
03-19-2020, 07:08 AM | #22 | |
Rep 3,152
I really believe 700 is the threshold for reliability when tracking or racing pretty often. Excited to follow your build. Please post pics during install!
mdma-zn51.50 |
