      12-01-2019, 06:13 AM   #1
motosportm4
Drives: bmw m4
M4 START
after firing the car the revs go crazy and the engine can go out. It always happens when the car is standing a few hours. Can anyone help?
      12-01-2019, 06:19 AM   #2
G35POPPEDMYCHERRY
G35POPPEDMYCHERRY's Avatar
Drives: F80
gotta pull some codes.
plugs/coils
intake?
people with more knowledge will chime in
      12-01-2019, 06:59 AM   #3
motosportm4
Drives: bmw m4
no mistakes. intake system I have EVENTURI CARBON. I replaced New: Candles plugs and injectors. D
I have no idea what's going on
      12-01-2019, 11:25 AM   #4
andrei.m4
Drives: bmw f82
Install stock intake
      12-01-2019, 11:42 AM   #5
Luc@Speed&Tech
Luc@Speed&Tech's Avatar
1254
Drives: G80 M3 & E92 M3
Had this exact issue when I installed my Eventuri intakes a while back. Just had to tighten down one of the clamps on the silicone couplers.
Speed & Tech Motoring
23585 Overland Drive, Unit 178
Sterling, VA 20166 (Headquarters)
23541 Pebble Run Place, Unit 140
Sterling, VA 20166 (Satellite shop)
      12-01-2019, 01:40 PM   #6
motosportm4
Drives: bmw m4
Reading this forum I read that the problem may be EVENTURI intake. That's why I checked all connections very carefully. Despite this, the problem is still there After uploading the MHD program, the problem subsided for one day, but after driving a few kilometers and the next day firing again, the speed jumps.I upload the STOCK maps again and the car starts normally, when I drive the car again the next day when firing, the revolutions go crazy. I upload the mhd map again, e.g. STAGE 1 STAGE 2 STOCK, this car can stand in the garage for a few days and each time after starting the engine the speed is good. just drive a few kilometers and the problem returns
after each FLASH the car fires up and works normally until you drive a few kilometers and the problem returns .....
      12-01-2019, 02:24 PM   #7
jpy1980
jpy1980's Avatar
Try installing your stock intake and see if the issue persists. Could also maybe be your maf sensors.
      12-01-2019, 03:05 PM   #8
motosportm4
Drives: bmw m4
Will mount the original intake and check. Are these two sensors in the entry you write about them?
      12-01-2019, 03:39 PM   #9
jpy1980
jpy1980's Avatar
I don’t know what you mean but here’s a good tutorial on how to clean your maf sensors:
      12-05-2019, 08:50 AM   #10
sicck_m4
sicck_m4's Avatar
168
Drives: F82 Yas Marina M4
Check your mass air flow sensors. Make sure there is no damage and installed proper direction of air flow.
M4 Yas Marina Blue
F32 Estoril Blue
      12-08-2019, 02:45 AM   #11
motosportm4
Drives: bmw m4
after uploading map stock, stage 1, STAGE 2 the car works normally. The problem starts when I arrive a few kilometers and start the engine the next day?
      12-08-2019, 02:46 AM   #12
motosportm4
Drives: bmw m4
after uploading map: stock, stage 1, STAGE 2 the car works normally. The problem starts when I arrive a few kilometers and start the engine the next day?
      12-08-2019, 08:16 AM   #13
rapsquared
Drives: 2015 M3, 2011 Lotus Evora
Have you followed the advice thus far? A fresh flash takes all of the learning away. Likely a leak after the MAF that the ECU cant compensate for. Reinstall OEM intakes or at least check MAF sensors in the Eventuri setup. A good shop can read MAF signals, maybe a sensor or wiring was damaged?
      12-08-2019, 09:35 AM   #14
motosportm4
Drives: bmw m4
today such errors popped up .......
      12-08-2019, 12:49 PM   #15
carbon//m3
carbon//m3's Avatar
Drives: m4 vert
Stop trying to self diagnose with all those misfires and take it to a reputable Bmw mechanic and have it checked.
      12-08-2019, 01:12 PM   #16
motosportm4
Drives: bmw m4
the car was at several BMW mechanics. Replaced: valvetronic engine, candles, injection. Still the fault and problems is with the morning start only stopped clicking after waking the car as the valvetronic engine was replaced. But the problems with starting the car are still there and these errors are sent which I send after replacing the vvt engine. I am looking for help here because in my country nobody knows what is happening with this stupid M4!
      12-08-2019, 01:32 PM   #17
carbon//m3
carbon//m3's Avatar
Drives: m4 vert
Put it to stock 100% make sure your MAF are installed correctly and not dirty.
      12-14-2019, 08:11 PM   #18
TheirThere
867-5309
76
Drives: F80 M3 ZCP and E36 328i
2017 BMW M3  [0.00]
i was having the same sort of cold start issues.
disabled the cold start option on my MDH tune.
car is back to starting and running silky smoothhhh.
(my neighbors hate me, again)
