Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > UK
      04-15-2019, 05:18 PM   #1
Paul SR
Drives: Touring
BimmerCode cheat sheet
Anyone know how I can obtain the cheat sheet for expert mode? Never used expert mode before is this straightforward to use or is there a big chance of bricking the car?
Thanks
      04-15-2019, 11:17 PM   #2
BadM4
BadM4's Avatar
Drives: 2018 IND TANZANITE COMP M4
Lol just code it the normal way
2018 Individual Tanzanite Blue M4
      04-15-2019, 11:28 PM   #3
Vergis
Not worth the risk imo
      04-20-2019, 02:52 AM   #4
rhm_SIIM4
Drives: MY19 M4 CP (SMB)
Thanks
There are some around on the net. I used expert mode to fine tune the ASD - keeping it activated but making volume minimum. Details are out there but not sure they are all in one place. That said, ASD is now coded fully off in mine as I got bored of it in the end. There isn’t much you’d want to do that BimmerCode doesn’t cater for ... what are you trying to code?
R.
Paul SR42.50
      04-28-2019, 04:53 AM   #5
m3centurion
Thanks
This may help
Paul SR42.50
zedman12.00
      04-29-2019, 10:38 AM   #6
Paul SR
Drives: Touring
Wanted to see if I could code in the changes rather than using a coder. I will have a look at the above but looking at expert mode on BimmerCode appears to be really difficult and no idea what it all means lol.
      04-30-2019, 06:31 AM   #7
m3centurion
It may look complicated, but it is very straight forward. Bear in mind that every time you use Bimmercode, it makes a backup so if you are not happy you can always restore the backup. I coded video in motion a few months ago and decided last week to reverse it by restoring from backup. So it's great in that respect, as you can access all the backups going back many months
Paul SR42.50
      05-04-2019, 11:31 PM   #8
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Here's something to get you started:
https://f30.bimmerpost.com/forums/at...8;d=1435767715
Paul SR42.50
      05-05-2019, 12:51 AM   #9
domino_z
Drives: F-Pace SVR
Comfort access on drivers seat
      05-06-2019, 04:22 AM   #10
m3centurion
https://f30.bimmerpost.com/forums/at...8&d=1435767715
Do any of these work on the M3 or M4?
      05-06-2019, 04:23 AM   #11
m3centurion
Does this work on the M3 or M4?
      05-06-2019, 04:48 AM   #12
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Many modules are interchangeable so yes. It's not like the M4 has a different FEM unit.
      05-09-2019, 09:59 AM   #13
Paul SR
Drives: Touring
Can you control exhaust flaps with bimmercode?
      05-09-2019, 01:48 PM   #14
m3centurion
I’ve tried this in the past on my M4 without success.
I’ll try again.
      05-09-2019, 02:21 PM   #15
t5pilot
t5pilot's Avatar
Drives: M4 CP & S1000 XR
No mate. It's engine ECU.
/// BM3 + M-Power ///
      05-10-2019, 10:09 AM   #16
Paul SR
Drives: Touring
You are quite right - I think you can on Bimmerlink. Need to get rid of active sound - is it better to unplug or code through bimmercode?
      05-10-2019, 10:17 AM   #17
t5pilot
t5pilot's Avatar
Easier way is to code it out with Bimmercode. I did this initially. When I fitted my additional amplifier I then unplugged the ASD module. It's a pain to get to just to unplug it if you're not doing anything else...
Paul SR42.50
      05-10-2019, 10:22 AM   #18
Paul SR
Drives: Touring
You are probably right although I was sure someone had an issue with the coding out. Need to put the BMC filters in shortly.
      05-10-2019, 10:35 AM   #19
t5pilot
t5pilot's Avatar
Thing is, with Bimmercode, it's so easy. You'll know straight away if it's worked, as once it's disabled, you'll be surprised just how much artificial sound was being pushed through your speakers.
I don't suppose you can beat actually unplugging the module though for true certainty it's disabled. Just be careful unplugging it if you don't have HK audio, as I think it causes issues with other sounds. ie. radio & chimes...
      05-10-2019, 10:39 AM   #20
Paul SR
Drives: Touring
I have the HK audio but I think coding it out will be easier. Might practice some coding on my wifes 1 series before doing mine
AIRHEIR443.50
      05-10-2019, 12:01 PM   #21
t5pilot
t5pilot's Avatar
Lol, honestly, no need to practice, it's a doddle
      08-10-2019, 03:35 AM   #22
AlxBaron1
Drives: BMW 328i 2016
R.
Hi, would you kindly share the expert mode instructions (or link) for ASD? I would like to set it the opposite, to the max. Thank you!
