01-03-2024, 07:41 AM | #1 |
Rep 100
caster monballs or non-adjustable
I'm thinking of getting monoballs before next season to reduce the squirm under hard braking. I love adjustability, but in this case, I'm note sure it's worth the hassle and cost. What does caster adjustment do for me besides change the weight of the steering?
01-03-2024, 08:27 AM | #2 |
Rep 836
Presumably you'd run less static camber with more caster. less static camber should improve straight line traction. Maybe a bit better tire wear? Never done it myself though.
01-03-2024, 03:25 PM | #3 |
Dont listen to me
795
Rep 562
I think going with caster adjustable monoballs is a decision that involves several other factors to figure out if that is the location where you want/need to be adjusting all of your caster or just a portion of your final caster adjustment.
I'll start by saying I dont know how much you can increase caster via a thrust arm monoball location before you start moving the wheel too far forward in the arch to where you start rubbing while turning. Do you have upper camber/caster plates already? Depending on the plates, you may find that moving the plate rearward to get extra caster ends up blocking access to the bolts for camber adjustment. That isn't great if you swap between a street and track camber setting a lot. If you do, you are basically forced to move the caster plate back as far as you can while still having access to all of your camber adjustment bolts. In that situation, having the ability to add more caster (that you could have gotten from the top) by adjusting the monoball would be a nice option to have. What tire sizes are you running and do you have any rubbing in front or back of the tire? Having the ability to change the location of how the wheel/tire fits in the fender arch is nice for some applications where wheel fitment needs some tweaking.
Instagram: @thatwhitem4
01-04-2024, 04:19 AM | #4 |
Rep 5,548
Increased castor improves high speed straight line stability, improves cornering feel, increased self centering, steering weight and increased negative camber while turning. With a strut front suspension, you want increased negative camber because the camber gain with suspension compression is poor so camber-castor plates help with increasing both static and dynamic camber. Amount of typical increase in castor usually isn’t enough to reduce static camber but it does help some with improved camber while turning. Castor adjustments do help with overall improved suspension geometry.
01-07-2024, 08:20 AM | #5 |
Rep 1,335
The adjustable arms must always go with camber plates, if you mount all the front arms with monoball you will never want to go back, the steering feeling is impressive with monoballs.
You should also mount the motor mount inserts of m4 gt4, since with a monoball the engine tends to move more. |
