10-27-2017, 06:04 PM | #1 |
Rep 12,654
proTUNING Freaks | bootmod3 S55 M3 M4 | Stage 1 & 2 Comparisons
World's first custom mobile flash tuning platform for the BMW F series. Developed and tested in-house from the ground up over the course of almost 2 years with more features being added regularly makes the bootmod3 platform a custom BMW factory DME tuning solution like no other on the market today. Build the ultimate tune for your S55 powered vehicle and go from stock to full race calibration, and everywhere in between, with a map switch in the provided mobile app. bootmod3 calibrates the factory vehicle modules over the OBD port in a matter of minutes in the convenience of your driveway or anywhere internet access is available. bootmod3 app and cloud services offer many unique features not found in any other flash tune including and currently available: 1. Mobile app (iOS and Android) and Web (http://www.bootmod3.net) 2. One OTS map/tune included with the purchase 3. Datalogging over 200 diagnostic channels, up to 40 channels concurrently 4. Datalog sharing and charting without a need to upload to 3rd party websites or apps using the mobile app or web browser 5. DCT TCU (transmission) flash for maximized clutch clamping force extending life on stock and upgraded DCT clutch packs 5. Cloud based storage for map data and datalogs 6. Reverting back to stock performance map 7. Live Dash - realtime vehicle parameter monitoring via in-app guages 8. GTS TCU Flash for DCT vehicles 9. Diagnostics 10. Read and clear trouble codes in all vehicle modules 11. Reset learned adaptations (octane, knock, Valvetronic, etc) 12. ECU power reset 13. (Optional) Off the shelf (OTS) tunes for 91/93/Race gas/E85 octane at $100 per map 14. (Optional) Custom tuning for non-standard vehicle hardware and alternative fuels such as E85 and race gas 15. Customization of an existing OTS map $300 per map 16. Prior OTS map purchase required Some of the map features provided: - Top speed (VMAX) limiter removal - Higher rev limiter - GTS Startup Roar - Cold start cat heat cycle removed (for off-road use) - Cat efficiency check removed (for off-road use) - Exhaust valve control and overrun (burble) - Maps for upgraded Stage 1 and Stage 2 turbos - E85/blend, race gas and meth injection tuning - Custom Throttle mapping - Backend Flash maps for use with piggybacks such as the JB4 bootmod3 Stage 1 OTS map testing - 93 octane, dyno - 100+whp/wtq over stock baseline The car is a non-ZCP, stock hardware outside of K&N drop in filters. The car is also still on stock spark plugs with 47k km (~30k miles) on the odometer. Thumbs up bootmod3 Stage 2 OTS map finalized - 93 octane, dyno Decat downpipes and retuned. Only mods on the car are K&N drop-in panel filters and decat downpipes. |
03-14-2018, 11:36 PM | #10 |
You got my money?
3247
Rep 4,715
Drives: Ice Cream Truck
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
07-26-2018, 11:18 AM | #13 |
Rep 395
Dyno Overlay Stock vs OTS Stage 1 vs OTS Stage 2 93
I figured I would add something onto here to help people who were comparing them.
Dan@AutoTalent147.50 |
02-21-2019, 02:18 PM | #16 |
Rep 531
03-05-2019, 03:20 PM | #18 |
Rep 12,654
Bump! www.AutoTalent.com
03-29-2022, 06:24 PM | #22 |
Rep 175
Drives: TOO FAST
yes you can, you jus select one of the OTS tunes, then customize the burble to how long you want it to last, and aggressiveness .
Daily - '19 Sapphire Black F82 M4CS
Garaged - '10 Jet Black E92 M3 6MT Garaged - '03 Silverstone AP1 S2000 |
auto talent, bootmod3, protuning freaks, stage 1, stage 2 |
