12-29-2021, 12:32 PM | #1 |
Rep 6
Hey guys I'm currently runing a 255 40 265 40 set up on my volks I was curious as to why most guys run 35s ?? I don't see many 40s on here pic of how it sits below
[IMG][/IMG] |
12-29-2021, 03:21 PM | #5 | |
1288
Rep 1,955
If you went 265/35 R19, the diameter increase is only 1.2% and the speed different at 60 MPH is like less than 1 MPH.
F80Santos1.50 |
12-31-2021, 12:40 PM | #6 |
Rep 34
I run a front tire size of 255/40r18 on my TEs. In hindsight, I would go 265/40 on my next set of tires. I like the 40 series sidewall because it accounts for the diameter decrease when going from 19s to 18s. I could be wrong but I believe most of the track guys don't run 40 series tires because typically that results in excessive sidewall deflection
12-31-2021, 04:21 PM | #7 |
Rep 919
If you disable TC then you don't need to worry about tire diameter unless your concerned with speedometer accuracy.
I'm always TC off but only because it allows me to defeat the rev match. |
01-10-2022, 06:39 PM | #9 |
1288
Rep 1,955
03-03-2022, 05:19 PM | #11 |
Rep 257
Swapped out 19 inch TE's with a 30 wall tire for a 18 inch TE's with a 40 wall tire. Stock height. Like the 18s with a big sidewall better
12-07-2023, 10:30 AM | #12 |
Rep 12
