05-16-2018, 02:36 PM | #1 |
Rep 1,672
Drives: M2 CS | M135i
Front PSS wear (265/30/20)
Hi !
I wanted to know if anyone had also noticed such wear on the outer side of the front tires? I often drive in the mountains and the tires are about 4000 miles long. On my ex M3 equipped with 18 inches, wear was mainly on the inner side ... thank you in advance! Here are pics:
2020 M2 CS DCT
2021 M135i xDrive ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe |
05-16-2018, 11:18 PM | #2 |
Rep 2,924
Nope. Thats the first. Tires might be faulty..
Currently: '24 Mercedes G63 | '24 Porsche GT3 RS | '24 Volkswagen GTI
Previous BMWs: 340i, 740i, 745Li, M3, M4 Previous Others: Audi, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen |
Hedoniste3834.00 |
05-17-2018, 12:43 PM | #3 |
Rep 1,672
Thank you. I will ask my dealer about that...
2020 M2 CS DCT
05-22-2018, 11:13 AM | #4 |
Rep 1,481
I'd bet alignment is off before tires are faulty.
Hedoniste3834.00 Poiseuille5392.50 |
05-22-2018, 03:02 PM | #6 |
Rep 1,672
Thx for your comments. I appreciate I dont think its rubbing. Maybe it is due to my garage access which is a total shit. I will check this way too...
2020 M2 CS DCT
05-24-2018, 04:56 PM | #9 |
Rep 1,672
Tire pressure are OK...
2020 M2 CS DCT
05-24-2018, 04:57 PM | #10 |
Rep 1,672
Yes...
2020 M2 CS DCT
05-24-2018, 05:05 PM | #11 |
Rep 3,737
Drives: 2016 M4 DCT Tanzanite/Amaro
If it's the same on both sides, then it's probably the result of simultaneous impact, one time. Railroad tracks, stuff like that. I'm pretty confident they don't let cars out of the factory misaligned, they've always been pretty careful about that. So you already know you have to have the alignment checked and probably corrected, just be careful where you get it done. Most authorized dealers are pretty good with that, and have good equipment. If you go with an independent, be sure to look at what kind of cars he's been working on, and check his equipment. Personally, I like Hunter. Good luck!
Hedoniste3834.00 |
06-01-2018, 08:58 AM | #12 |
Rep 865
So in my opinion there are a couple of issues that your pictures are showing.
Is this picture of the wheel well liner? In this picture, you have two items going on. Between the blue lines, the feathering shown here occurs when the tire is sliding and rotating at the same time....like when cornering aggressively, but can also be alignment (Toe) as others have said; the Caster setting can also contribute to this or some combination. The pattern between the red lines is caused by the tire running continuously on its edge; meaning the top of the wheel is tilted just slightly outward when under normal load and going straight...most likely an alignment issue (Camber), but can be caused by other suspension issues also. Tire pressure can come into play also, but typically shows on both sides (under inflated) or in the middle (over inflated). This picture is of one of the rear tires off my car showing some wear on the inside of the tire; meaning the top of the wheel is tilted just slightly inward. Both sides are wearing the same and my fronts are showing similar wear indicating most likely an alignment issue for mine. I'll find out early next week when it goes in to have the suspension checked. The reality is that getting perfect wear on wide tires is nearly impossible. There is always some compromise going on which prevents the tire from rolling perfectly flat on the road.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 Last edited by MN2///M; 06-01-2018 at 09:12 AM.. |
Poiseuille5392.50 Hedoniste3834.00 |
06-01-2018, 12:19 PM | #13 | |
Rep 3,737
Hedoniste3834.00 |
06-03-2018, 03:24 PM | #14 | |
Rep 1,672
I cleaned a bit a part of the front tire today... Here are 2 more pics... I will ask my dealer about that asap.
2020 M2 CS DCT
06-03-2018, 06:26 PM | #15 |
Rep 20,741
You beat me to it. I was just about to ask if he is rubbing, because the wear pattern is more reminiscent of rubbing than excessive wear from driving.
OP, are you running spacers? If you are, there is not much the dealer can do...
Hedoniste3834.00 |
06-04-2018, 12:45 AM | #16 | |
Rep 1,672
I never used spacer. It seems strange to me to rubb on a full stock car...
2020 M2 CS DCT
06-04-2018, 01:39 PM | #17 |
Rep 1,672
I just saw this... « similar » wear for the apextaxi (F80)
Here is the full vid: (@ 11:20)
2020 M2 CS DCT
06-05-2018, 11:05 AM | #18 |
Rep 1,672
Car is going to the dealer in two weeks (19th of June). They will check the alignment.
2020 M2 CS DCT
06-05-2018, 09:40 PM | #19 |
Instagram: matte_f80_competition
127
Rep 219
have had similar issue (see the 2 pics attached) - excessive tire wear on outer edge of left front tire. no other misbehavior (car is going straight, no vibration from steering etc.). tire pressure is correct. will have the alignment done hopefully to resolve the issue...
18' M3 (F80) ZCP 6-Speed - IG: matte_f80_competition
Ind Frozen Dark Grey/M-Perf CF Pkg/MPE/KW CS 2-W/Girodisc+Carbotech/Vorsteiner VFF103 Track: Michelin Pilot Sport Cup 2 F: 265/35-19 R: 285/30-20 Street: Michelin PS4S F: 265/30-20 R: 285/30-20 |
Hedoniste3834.00 |
06-06-2018, 12:24 AM | #20 | |
Rep 1,672
I will keep you current
2020 M2 CS DCT
07-09-2018, 04:41 PM | #21 | ||
127
Rep 219
Hedoniste3834.00 |
07-10-2018, 01:37 AM | #22 | |||
Rep 1,672
My tires are now checked by Michelin... my car had no alignement issue so they gave me free front tires . I didnt track my car and tires had 6500kms. Never had this on my previous M cars... i will update if Michelin gives me a feedback
2020 M2 CS DCT
