07-18-2018, 12:17 AM | #1 |
Rep 289
Do the throttle settings affect DCT clutch wear?
Which of the throttle settings results in the most clutch wear? Intuitively it would seem the Efficient throttle would slip the clutch a little more and could result in greater wear, but I’m just guessing.
Also, is D harder on clutches than manually shifting the DCT? This is my first two-pedal car so am just curious as to what to expect.
'17 i8 Protonic Red Edition; '17 “30 Jahre” M3
'90 Z1 Red w/red/black leather, GC coilovers, Alpina Dynamic DS-02 '91 850i Mauritius Blue/Black, BBS RS-GT '85 M635CSi Alpine w/buffalo; '03 M3 Conv, Imola ‘85 323i Baur; ‘02 X5 4.6is Estoril; ‘95 Racing Dynamics K30.4 |
07-18-2018, 05:27 AM | #2 |
Rep 20,741
I don’t believe the engine setting has much impact on clutch slip. You should ask about what DCT Drivelogic setting people use, because clutch slippage is mostly related to the DCT Drivelogic setting.
In general terms, DCT will slip the clutch more in S1/D1 than is S3/D3 to achieve smoother upshifts and to rev up the engine on downshifts. Further, I think driving style will have much more effect on clutch wear than the engine setting.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 07-18-2018 at 11:45 AM.. |
stormlv932.00 |
07-18-2018, 07:57 AM | #3 |
Seeking mental floss
482
Rep 806
I agree. I do not like the D1 drivelogic setting, and always set mine to D2, which I find much more pleasant in traffic, and in normal driving. The downshifting this program does often means I do not need brakes while following in traffic, as the engine slows the car adequately, except in very quick stops, and I can let it coast in 1st or 2nd gear without it unecessarily shifting to a higher gear. I suspect S1/D1 would be the most clutch wear.
07-18-2018, 08:44 AM | #4 | |
Rep 289
07-18-2018, 11:43 AM | #6 |
Rep 20,741
Slip is slip and will induce wear. However, the wear is indeed less on a wet clutch setup. This thread remains theoretical as the DCT clutches should outlive the car.
07-19-2018, 12:37 AM | #8 |
Rep 289
I was thinking the same thing as I just discovered creep mode two days ago. I’ve been driving in manual shift mode since I got the car (it’s the only way I will even drive my wife’s e46 M3 SMG). Accidentally bumped the shifter into D and was pleasantly surprised to find the car will creep forward on its own in stop n go traffic. Very nice!
07-19-2018, 01:39 AM | #9 | |
Rep 4,381
Tap the throttle and off it creeps...shift to S2 to go a little faster.. |
CigarPundit1391.50 steve198060.50 |
07-19-2018, 08:16 AM | #10 | |
Moderator
7512
Rep 19,368
If so, and if your use of the colloquial "stop n go traffic" is indeed meant to communicate that you are genuinely bringing the vehicle to a full stop, and depending on what you meant by "creep forward on its own", you may be causing undue wear to the clutches. As mentioned in the user manual, you must apply the brake firmly when coming to a stop to tell the transmission to open the clutch(es). By contrast, it is also possible to bring the car to a stop with your foot resting on the brake, yet not fully applied. In this case, the DCT may keep the clutch on the edge of engagement which would obviously not be good for the clutch pack. If you are indeed able to get the car to move forward from a stop on its own power (i.e not downhill) merely by lifting your foot from the brake pedal, you are not applying the brake hard enough to disengage the clutches. Yes, this will allow the car to behave as if it has a torque converter like a vehicle with a traditional automatic does, but it will come at the expense of premature wear. |
07-19-2018, 10:46 AM | #11 | |
Rep 272
07-19-2018, 12:28 PM | #12 |
Rep 708
Low speed assistant (creep mode) is invoked from a complete stop. Tap the accelerator in D or M, and the car will idle forward - you can also upshift to 2nd.
Cheers
Bye bye E93 M3 - Hello F83 M4! |
CigarPundit1391.50 |
07-19-2018, 12:56 PM | #13 | |
Rep 3,396
07-19-2018, 12:57 PM | #14 |
Rep 4,976
I don't think that's the reason. If so, BMW wouldn't be able to able to move these cars as well as it has. It's definitely a cost thing more than it is a Auto people don't get it. I mean we have had two generations with DCT, that's definitely not it IMO.
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
07-19-2018, 01:12 PM | #15 |
Rep 3,396
A reason, not the only one to which I’m sure costs are a big consideration along with LT reliability. I’ll also add BMW market focus seems to be drifting from performance oriented to more of luxury sportiness so no need for a dct to satisfy the average driver, this of course just a guess based on production sales numbers I’ve seen. Be nice if they planned to keep the 6 speed manual tranny for the performance minded along with the torque converter auto but I know the 6T is gone as well.
Thescout134944.00 |
07-19-2018, 01:20 PM | #16 | ||
Moderator
7512
Rep 19,368
I agree with the other poster - it boils down to cost. And specifically, it is likely that a dwindling number of potential buyers will consider the DCT a reason to choose a BMW over a competitor's model with a traditional automatic (which all other vehicles in this segment now have). So BMW has probably determined they can no longer sustain revenue by passing the would-be higher costs to the consumer. In other words, equipping the car with the DCT won't bring in any more money than equipping it with the ZF, and might even bring in less. |
07-19-2018, 01:29 PM | #17 | |
Rep 4,976
07-19-2018, 01:31 PM | #18 |
Rep 3,396
I think so too, but the manual is barely treading water.
07-19-2018, 01:56 PM | #19 | |
Moderator
7512
Rep 19,368
The next M2 is so far off anything could happen. An MT is still a reasonable bet, but it will be the better part of five years before that car comes to market. It'll be a few more years until there is a clear picture. |
07-19-2018, 02:00 PM | #20 | ||
Rep 4,976
07-19-2018, 02:07 PM | #21 | |
Rep 3,396
07-19-2018, 02:20 PM | #22 | |
Moderator
7512
Rep 19,368
Thescout134944.00 |
