R44 Performance
      11-11-2019, 07:17 PM   #1
10bmw10
Drives: Frozen Portimao Blue G80
Whats the best way to make these wheels fit? Thanks for the help!
Please help me figure out how I can fit my Audi BBS LMs fit my car.
2016 BMW M3
Wheels 19x9.5 5x112 et32 (front and back)
Tires 265/35/19 (front and back)
I'm assuming I could buy:
https://wheeladaptersusa.com/product...=5456747823135
What else do I need?
Would i need spacers?
Any info helps.
Thanks
      11-12-2019, 09:10 AM   #2
F80Speed77
Grid.Life
F80Speed77's Avatar
Drives: BMW M3
The wheel adapters are technically a spacer so that should be all you need. I think you'll want a little less thickness on the adapter like maybe closer to a 10mm or 12mm if possible. Also I think youll want 5x120 to 5x112 adapters not the other way around like you have in that link.
      11-12-2019, 09:57 AM   #3
f80er
Drives: An M3
Why though?
      11-12-2019, 01:04 PM   #4
10bmw10
Thank you!
      11-12-2019, 01:06 PM   #5
10bmw10
Originally Posted by f80er View Post
Why though?
Mainly because I spent 5k on wheels and tires a few months ago for my Audi and reselling wheels doesn't get me enough to do it all again for this car.
      11-13-2019, 01:00 AM   #6
Justin.AutoTalent
Fitment isn't going to be all that great another concern is will it clear the brakes. I know that on the RS5 that fitment requires a spacer to clear
      11-13-2019, 01:26 AM   #7
10bmw10
They fit on my 2013 S5 with no spacers.
As far as clearing my m3s brakes, do you think I should also add spacers?
      11-13-2019, 02:19 AM   #8
Justin.AutoTalent
I wouldn't really be able to give you much advice without seeing the barrel clearance. You're going to need spacers regardless to make the fitment flush
Fitment would probably be 10mm front and 18-20mm rear
The straightforward answer would be to not waste your time making it work. Coming from a wheel whore, I would take the loss on the wheels and recycle the money to another option for the M3.
Only if you don't have the S5 anymore though
