08-25-2021, 09:59 AM | #1 |
Rep 12
CarPlay Upgrade Success!
I'm not sure if this is the appropriate place to post this, but I recently had kubax86 (@kubax86) upgrade my 2016 M4's CarPlay from V4 to V6. Everything works as if it were OEM; it took about an hour. If you, as I was, are curious as to whether it "works" or not, I'll vouch that the guys at https://bimmer-remote.com/ knocked it out of the park.
08-27-2021, 02:56 AM | #2 | |
Rep 3,056
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-29-2021, 07:22 AM | #4 |
Rep 3,056
Unfortunately not. Headunit is too old.
09-01-2021, 02:16 PM | #6 |
Rep 4,983
So there is this for us lowly 2015 owners:
https://retrofitmybimmer.com/ You do lose iDrive navigation though |
09-01-2021, 02:34 PM | #8 | |
Rep 606
09-01-2021, 05:26 PM | #9 | ||
Rep 4,983
09-02-2021, 08:18 AM | #10 |
Rep 606
Well damn. I was just getting into investigating this as id like to upgrade mine as well. Cant do anything to this car without dropping $1500 haha.
09-02-2021, 08:32 AM | #11 |
Rep 3,056
You can get MMI to get CarPlay on current unit
09-02-2021, 08:39 AM | #12 |
Rep 606
That would be a hell of a lot cheaper than getting a new head unit!
09-02-2021, 09:16 AM | #13 | |
Rep 4,983
Tell me more.. edit: Found it, yeah, not a fan. Seems to overall degrade the system. Last edited by Jockey; 09-02-2021 at 12:29 PM.. |
09-05-2021, 02:08 PM | #15 |
Rep 564
got the andream carplay mmi for $260 and couldnt be happier. really better than the oem setup (comes with youtube which is a game changer) and allows me to control carplay from the steering wheel (which you cant do with oem). blown away. took 2 hours to install. if i had a 2016 i would do the coading no brainer. but with 15 mmi ALL THE WAY
F83 M4 - SIX SPEED
Build thread: 2015 F83 Mineral Grey 6-Speed Manual https://f80.bimmerpost.com/forums/sh....php?t=1856042 |
09-05-2021, 08:33 PM | #16 | |
Rep 1,004
09-05-2021, 09:12 PM | #17 |
Rep 564
Just do a quick google search.
Here is the video I used to install. All the info you'll ever need https://f30.bimmerpost.com/forums/sh....php?t=1675929
F83 M4 - SIX SPEED
09-05-2021, 09:15 PM | #18 |
Rep 564
I would keep the oem screen. It's better than any Chinese screen
F83 M4 - SIX SPEED
09-23-2021, 02:28 AM | #19 |
Rep 3,056
Definitely yes. OEM is OEM
09-23-2021, 11:13 AM | #20 |
Rep 80
Drives: 2017 F80 ZCP DCT
For folks who have successfully upgraded to ID6, have you noticed any problems? I read in another thread about the OEM navigation crashing with route guidance. While I would love to have full screen CarPlay, I'd rather not have to deal with other issues.
Also, for the flash process, what do folks use to maintain power? I believe a battery tender/charger will not be able to provide the needed voltage for the flash. |
09-30-2021, 02:05 PM | #21 |
Rep 12
I can only speak for myself, but my install turned out absolutely perfect. You'd never know it wasn't OEM. WRT navigation, I only used the factory NAV once because I generally use Waze via Carplay. But that worked fine the one time I used it.
I just connected a trickle charger to the battery and that worked fine for my install. |
09-30-2021, 03:51 PM | #22 | |
Rep 80
For the power supply, I did a bit of research and will most likely pick up a CTEK Multi US 25000 that can supply 12V/25A. Just want to be safe and avoid battery drain during the flash. I recently had Kubax86 do the GTS flash, but that was only 15-20 mins. The ID6/CarPlay flash looks like it will take up to an hour. |
bimmer-remote, carplay, kubax86 |
