07-30-2016, 11:49 AM | #1 |
Rep 1,904
19x10 Square Setup for Track Use (Photos)
There's been some discussion about a square setup for track use on the F8X. Particularly with 19 inch wheels and CCB's.
I just finished mounting Four Apex Arc-8 19x10 ET 25 wheels with Michelin Pilot Sport Cup 2 265/35-19 tires. I ordered the wheels direct from Apex and the tires from Tire Rack (heat cycled) and my BMW SC mounted and balanced them. Clearance looks good all around. Lots of clearance between the CCB rotors and wheel. Suspension components clear fine. I tested the car lock-to-lock without any rubbing. I am running just a bit of extra camber up front (-2.0 vs factory -1.5) but will be increasing the camber to -3.0 shortly. I wanted to check clearance before I increased the camber just to see how they fit. I haven't been to the track yet with these but I'm looking forward to extending my tire life significantly by being able to move the wheels around to any corner on the car to balance wear. (The PSC2's are NOT a directional tire). Anyway, here are the photos if anyone is interested:
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 |
07-30-2016, 02:51 PM | #2 |
Rep 938
looks good.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
07-30-2016, 05:51 PM | #3 |
Rep 27
Looks good. Question, is the car lowered? I'm thinking of using the rear 359m's (from the E92 ZCP) all around on my M4 but am a little worried if the front will fit 10j +25 at stock height.
MovingChicane109.50 |
07-30-2016, 09:30 PM | #4 |
B.E.
444
Rep 761
Good shit. Text me when you get a chance
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
07-31-2016, 09:09 AM | #5 |
Rep 1,904
The car is not lowered. Stock M adaptive suspension. The only applicable mod might be the additional 0.5 degrees of camber I have up front (-2.0 total). However, in looking at the car right now, I don't think the extra camber matters for fitment though. I expect these wheels and tires would fit just fine on a pure stock suspension. I'll likely be pushing the camber to -3.0 today...
davem3fan185.50 |
07-31-2016, 11:09 AM | #7 |
Rep 20,741
Front camber is not adjustable on the F8X. You need camber plates for any sort of front camber adjustment.
07-31-2016, 12:45 PM | #9 |
Rep 1,904
Working on increasing the camber right now. I can only get about -2.4 with the GC plates before I lose access to one of the hex bolts that will need to be tightened. I will start a new thread regarding max adjustment on the GC plates...
07-31-2016, 01:26 PM | #10 |
Rep 283
Your car looks great! I'd be very interested how that square setup works on track...I guess steering must be a bit special with 10 in front...isn't there too much understeering then?
Kraut-Hero & (occasional) San Franpsycho
07-31-2016, 02:16 PM | #11 |
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Maybe more camber would help, but I've seen guys chunk MPSC2 in one day on a stock M4. Guy was pissed and had to go home on the first day of a 3 days track weekend.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
07-31-2016, 04:07 PM | #13 |
Rep 20,741
The GC plates are made with two setups. Once past a given camber angle, you lose access to two of the bolts (as you mentioned), you need to switch setup from that point and use the little shims provided and the retaining plate instead of the washers. With that setup, you'll be able to increas camber even more while still being able to use 4 retaining bolts.
07-31-2016, 05:19 PM | #14 | |
Rep 1,904
Do you have any additional info or photos of what needs to be done? Thx...
07-31-2016, 05:40 PM | #15 | |
Rep 1,904
07-31-2016, 06:19 PM | #16 |
Rep 1,904
That appears to be the trick! Thanks CanAutM3! Got a solid -3.0 now on each side.
Tomorrow, I'll re-set the Toe...
08-01-2016, 10:33 AM | #18 |
Rep 1,904
I looked at a bunch of Wings for the M4. The one I chose was imported from Germany. It is made by Motorsport24. (ACS also makes a couple of nice ones) IND can special order it for you if you want one. They also worked with Fall Line to custom make a couple of underside trunk mounts for me. I wanted something a bit more substantial than the default Motorsport24 mounting plates since I track my car...
You can find more info about my build here: http://f80.bimmerpost.com/forums/sho...ht=fire+orange and details specifically here: http://f80.bimmerpost.com/forums/sho...4&postcount=35
08-01-2016, 10:59 AM | #19 | ||
Rep 20,741
Also note that no washers should be installed on the retaining plate (as opposed to what is shown on the picture), otherwise there is very little tread left for the bolts. Quote:
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-01-2016 at 11:05 AM.. |
08-01-2016, 11:00 AM | #20 |
Rep 20,741
08-01-2016, 03:58 PM | #22 |
Rep 1,904
I started building my car in August of 2014. I was working directly with BMW M Studio in Munich. My intent was to build a look-a-like of the legendary M3 GTS they had at the M test center in Nurburg. My intent was to plate the car as "M4 GTS"...
However, about 6 months AFTER we started working up my build, BMW decided to build a real "M4 GTS"... So that kind of took the "M4 GTS" plate possibility off the table... "M4 GTX" keeps the spirit of the build without trying to be a poser. Plus "X" is traditionally a variable... So, who's to say, is it a GT3 spec car, GT4 spec car, etc...
