ARMA SPEED
      06-03-2017, 06:26 PM   #1
momo3605
Drives: M340i LCI, 718 GTS 4.0
M4 CS EDC Coding?
Any coders have an idea on this? Can this be done now? Apparently the M4 CS uses EDC with a different tune compared to civic M4s. Not sure if the hardware is even the same, or if it's even just the same as the zcp coding.
      06-05-2017, 02:33 AM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
I thought the M4 CS came out in 2018.
What are you looking to code?
M4 CS sits between ZCP and GTS, with extra power via tuning compared to water injection like the GTS. I have not seen anything specific to EDC.
      06-05-2017, 09:40 AM   #3
Doctor1973
Drives: Bmw M4 YMB
I am interested too for CS settings like EDC,DCT,Ghas,Dsc and steering.
Should be out something with Sw ISTA 3.62.0
Will see..
      06-05-2017, 11:54 AM   #4
momo3605
The CS is already out and being driven by reviewers as seen on bimmerpost homepage. If you read the press release, they mention new "tuning" of the EDC parameters (similar to zcp). That's what I was interested in.
      06-05-2017, 12:25 PM   #5
Almaretto
Almaretto's Avatar
2374
Are your press? I have only seen it released to select few. You are looking to code CS parameters onto a non-CS or looking to code some parameter onto a CS?
      06-05-2017, 12:32 PM   #6
Almaretto
Almaretto's Avatar
2374
Will see..
The latest software I have is ISTA-P 3.61.5 and ISTA+ 4.05.31. How can a vehicle be on the road and firmware not release?
      06-05-2017, 11:59 PM   #7
Doctor1973
Drives: Bmw M4 YMB
When yuo detect different settings please let us Know...thanks
      06-06-2017, 12:21 AM   #8
Almaretto
Almaretto's Avatar
2374
All I need is a Typenschlüssel and I will tell you what the settings are.
      06-29-2017, 02:00 AM   #9
M4 CSL
M4 CSL's Avatar
Australia
231
Drives: ///M4
How do you tell what your car has?
I finally convinced the dealer to upgrade my software to the most current, on my Civic M4. I would like to check and see what it is.
It sorted all my issues. Car feels great now. But woud like to know what version I have, and if I can tick some CP boxes?
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars |
      06-29-2017, 12:30 PM   #10
Almaretto
Almaretto's Avatar
2374
You can check I-Step or you can Read SVT and compare to previous saved copy.
      07-02-2017, 10:52 AM   #11
Doctor1973
Drives: Bmw M4 YMB
Any news for CS settings that can be coded on civic M4?
      07-13-2017, 01:56 PM   #12
RSXDC5
RSXDC5's Avatar
707
BUMP, very very interested in this as well
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      07-19-2017, 09:28 AM   #13
Doctor1973
Drives: Bmw M4 YMB
Need a CS Vin for that desidered customized settings?
      07-19-2017, 06:00 PM   #14
Almaretto
Almaretto's Avatar
2374
Yes.
      07-22-2017, 09:34 AM   #15
Doctor1973
Drives: Bmw M4 YMB
I have updates soon ,guys
terahertz162.50
      07-24-2017, 04:38 PM   #16
Doctor1973
Drives: Bmw M4 YMB
Finally I've got CS EDC files coded in my M4.
Big Thanks goes to Alex@alpine.
Let me test this setting for couple days for feedback.
First impression is stiffer compare to zcp edc.
PayamFSU209.00
iatacs19458.50
      07-28-2017, 04:00 PM   #17
DS_BMW
DS_BMW's Avatar
Drives: 2022 M4 comp, 22 M240
What is your opinion after a few days?
      07-28-2017, 05:05 PM   #18
evolmotorsprt
Drives: 2014 Porsche Cayman S
I'd like to know as well.
      07-29-2017, 01:13 PM   #19
LLNM4
LLNM4's Avatar
Netherlands
181
Drives: M4 F82 MG
Please, can you give us some feedback.
M4 F82, MG, stage 2+, ER catless DP, Akra, Armytrix, BMS intake, ER charge pipes, Ohlins R&T, GTS/CS hood, GTS flash, EDC CS, 763M CS rims, LCI taillights and LCI LED adaptive headlights
M5 F10, Singapore grey, stage 2
E92 335i RB upgrade turbo & FBO
      08-03-2017, 07:20 PM   #20
momo3605
bump! Feedback please!
      08-04-2017, 02:32 PM   #21
LLNM4
LLNM4's Avatar
Netherlands
181
Drives: M4 F82 MG
Got it done 2 days ago. Good and fast service from Alex@Alpine as always.
It's a improvement and the car feels stiffer in sport and sport + mode vs ZCP edc.
At high speeds the car is more stable compared to ZCP edc.
bordins145.00
      08-04-2017, 02:33 PM   #22
Almaretto
Almaretto's Avatar
2374
Originally Posted by LLNM4 View Post
Got it done 2 days ago. Good service from Alex as always.
It's a improvement and the car feels stiffer in sport + mode.
Were you switching from stock or GTS?
