09-27-2019, 04:30 PM | #1 |
Rep 518
This is how you make an S55 engine sound good!
The S55 M3/M4 engine sounds farty and raspy for 2 reasons. The farty V6 twin exhaust sound is caused by the exhaust manifold split with twin turbos and isolated outlets and the 2 midpipes needs to be joined into 1 to blend out the farty V6 note and this is what AA etc do with the single midpipe.
The raspiness is caused by stock resonator being too small and not packed with sound deadening so it's an open chamber resonator with an H pipe that emphasises raspiness. To get rid of the raspiness you "must" use perforated tube resonators packed with sound deadening preferably stainless wool as it doesn't burn out like fibreglass. With catless downpipes, you need 4 12" resonators 4" diameter in the midpipe to control noise with the valves open and create a smooth rasp free note. The reason all the aftermarket exhausts sound nearly as bad as stock but louder, is they don't use resonators or the resonators they use are too small and not packed with effective sound deadening material. This setup sounds magic with catless downpipes and stock rear muffler but unfortunately it seems that everyone is trying to get a decent note out of the S55 exhaust with straight un-resonated pipe and it's impossible! This is simply "old school" exhaust technology I've used to make V8's sound great that works just the same on the S55 engine as I expected. Last edited by RevNev; 09-27-2019 at 04:45 PM.. |
09-27-2019, 04:48 PM | #2 |
Rep 1,481
Post a sound clip.. that proves your point best
Seems like the modifications you did increases flow restrictions over OEM.. not exactly what most people want to do. The single mid pipe is the only tried and true way to get rid of most of the rasp while deleting factory secondary cats, even with straight pipes. Please post a clip. |
09-27-2019, 06:08 PM | #4 | |
Rep 518
The single midpipe doesn't get rid of the rasp at all. It blends the sequential pulses from each turbo outlet and gets rid of the V6 farty sound the same as joining the twin pipes into one. Raspiness is the metallically sound of a mechanical muffler or straight pipe that only perforated tube packed resonator removes. How to do think a V8 sounds with a twin 2.5" system, no mufflers and balance (X-pipe)? I'll post and audio clip soon. |
bradsm87595.50 |
09-27-2019, 06:43 PM | #5 | |
Rep 1,481
And really? You're going to compare a v8 sound to the s55? Let me tell you man.. you can do a hack job and just chop off any rear muffler on a V8 car to hear sounds that you will never, ever hear from our beloved S55. You're so quick to dismiss the AA mid pipe reducing rasp, which leads me to believe you haven't heard the setup in person... I hope your method sounds so great so I can do the same thing because AA mid pipe is the only setup to me that got rid of the rasp significantly. Last edited by JamesGames; 09-27-2019 at 06:52 PM.. |
papasmurf_m3454.50 judsonlct0.00 |
09-27-2019, 06:56 PM | #6 |
Rep 4,116
I stopped reading after you said V6 😂😂😂
37
red_guapo42.00 Studntloan581.00 TideMD291.50 NCThreePedals226.50 f8xdct158.00 nbennettksu1397.00 Gtracer53.50 ellipsis2121622.00 JRV118.50 prompt292.00 c4ss103.50 Revvvm3169.50 kern4174462.00 danchee136.00 bank14.50 behindthen0thing839.50 TheDailyDriven669.50 The_Werm214.00 JS_GT3RS43.00 fiveninerzero18.50 Alpine_F82215.50 kerkiraios00248.00 YasF80_SLO234.00 Graves1130.00 Ickdeep5726.00 manat.07.50 Lee808230.50 judsonlct0.00 Champagnekashi43.00 andrewBM40.00 StrizzyF804.50 SocoM37.50 sport6.00 Whyte_Diamonds260.50 SD ///M42993.00 Trevorstein150.00 ///BMW Junkie473.50 |
09-28-2019, 12:12 AM | #10 |
Rep 2,164
Guys, I don't think he was saying the S55 was a V6, he was saying it makes a sound like a farty V6 with twin exhaust. Kinda like when you modify a V6 Camaro with dual exhausts it sounds like sh*t lol.
I actually really enjoy the way the S55 sounds with just a mid-pipe, if you drive the car and hold the revs till the upper revs like 4-6k before shifting, it genuinely has an exotic tone to it. |
papasmurf_m3454.50 |
09-28-2019, 09:03 AM | #13 |
Rainbow Racer
1008
Rep 2,540
The S55 sounds the way it does because of the unequal-lengthed downpipes because the engineers wanted a symmetrical turbo inlet/outlets so packaging prevented having equal-length downpipes.
If you want that smoother "V6" like sound (or an N54 sound for that matter), you simply need to re-package the mid-pipes to create a equal-length piping prior to both banks merge into either an H-pipe or an X-pipe.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
The_Werm214.00 moonshine89151.50 |
09-28-2019, 09:12 AM | #14 |
#LSBM3
1424
Rep 1,973
Drives: 2016 BMW M3
Your exhaust build looks good. Would love to hear a sound clip. Even if it's just a quick video on your mobile phone.
/// M3 |
09-28-2019, 11:20 PM | #16 | |
Rep 131
You are correct sir. I did that with an old F80 M3 I had in 2016. I just bought another one and I'm on the path to 'fixing' the sound my new to me 2016 M3. BMW also shot themselves in the foot with the placement of the secondary cats, because they aren't equal distance from the primary cats, then on to the resonator where all that unequal horseshit blatty noise gets to mix together so everything on the F80 is garbage sound wise. And every exhaust maker hasn't ever come up with a solution except to make it louder. I can't wait for a single turbo kit to come out so I can get rid of all that crap....or make one myself I'll be done with my F80 sound project later this week, and I'll post pics/video
2019 AMG GTR
2001 911 Turbo 2021 Porsche Macan Turbo 2013 BMW X1 xDrive 35i |
09-28-2019, 11:58 PM | #17 |
I'm Batman!
3949
Rep 1,477
Agreed, I also want to hear a good sounding s55, has to be a unicorn
S55, 2JZ, M48.00 |
09-29-2019, 01:55 AM | #18 | |
Rep 518
What's wrong with the AA midpipe aside from single 3.5" flows less than twin 2.5"; they're too loud on a road car with catless downpipes and there's no room left under the car to fit resonators. With the valves open, catless downpipes and an AA midpipe, there's virtually no muffling capacity at all. |
bradsm87595.50 |
09-29-2019, 03:19 AM | #19 |
Rep 518
Here's a stationary video clip valves open
15minprior17.50 Brasko1423.50 phoenx332.50 HomoPirate84.00 f8xdct158.00 ///Mikey F80199.50 Poochie9107.50 prompt292.00 bradsm87595.50 |
09-29-2019, 05:10 AM | #20 |
Rep 648
I think my car sounds great with the M performance exhaust.
09-29-2019, 09:39 AM | #21 |
#LSBM3
1424
Rep 1,973
Drives: 2016 BMW M3
Thanks for posting that clip. I don't hear any raspy sounds. Very smooth and like a proper European car. Nice work!
/// M3 |
09-29-2019, 04:31 PM | #22 |
Rep 518
Here's an M4 GT4 race car with an Eisenmann X-pipe, resonators on the back and sounds great
The point is; if you don't join the midpipes in an X or collector and the exhaust doesn't pass through resonators with the valves open like most aftermarket systems, they'll never sound good and will retain the farty and raspy sound. Last edited by RevNev; 09-29-2019 at 04:39 PM.. |
