07-21-2015, 08:10 AM | #1 |
Rep 22,756
getBMWparts.com | Dinan F8x M3 & M4 Rear Suspension Link Kit!!!
Dinan F8x M3 & M4 Rear Suspension Link Kit!!! Product Description: Special Note: RACING ONLY PART. Alignment is required, but not included in the installation time. Dinan’s high performance Racing Rear Suspension Link Kit adds precision and predictability at the limit. The stock rear toe link is built with rubber bushings and a curved forged alloy rod which can easily flex. During hard acceleration this flex allows the rear wheels to have excessive toe change under hard acceleration and braking. All of this flex in the stock toe link causes the car to be unstable. Dinan® stops the flex by replacing the rubber bushings with Teflon coated machined steel rod ends and the OEM curved bar with a straight billet aluminum rod, thus adding stability. The Dinan rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment that is tough to achieve using the stock system. Like the rear toe links, the stock front trailing links also incorporate rubber bushings. Flex in these bushings allow the rear wheels to behave sloppily under heavy loads. Dinan adds precision by replacing these links with billet aluminum rods and Teflon coated machined steel rod ends. These front links are not adjustable, because there is no need to doing so. Benefits of the Dinan® Racing Rear Suspension Link Kit: + Replaces the stock rear toe link & rubber bushings with a precision machine black-anodized aluminum tube and racing-quality rod ends. + Replaces the stock forward lower trailing link & rubber bushings with a precision machine black-anodized aluminum tube and racing-quality rod ends.. + Dramatically improves vehicle stability during hard cornering. + Improves response by eliminating the deflection of the rubber bushings. + Rod-ends are Teflon-lines for quiet operation. + Rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment by simply turning the aluminum tube. This eliminates the need to struggle with the factory eccentric adjustment. + Only rear toe links are adjustable. Trailing links are not adjustable. + RACING ONLY PRODUCT Shop our F8x M3/M4 Dinan Performance Parts HERE!!! We'll match (and try to beat) any competitor's pricing on Dinan Parts!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! Last edited by Evan@Tischer; 03-24-2021 at 04:00 PM.. |
dinan, dinan links, dinan suspension, getbmwparts.com, tischer |
